Reading Groups in CopySOP ?
2104
11
1
Jan. 4, 2018 11:45 p.m.
Can the CopySOP read groups ?
【T】【C】【S】
AndyW
Jan. 5, 2018 9:28 a.m.
A little more specifically?
Jan. 5, 2018 10:31 a.m.
I have a group which I want to place copies created by the CopySOP in that group, but the CopySOP doesn't show the group which I created.
【T】【C】【S】
sepu
Jan. 5, 2018 11:04 a.m.
You can use the target point to put your group. If that is what you are asking.
Jan. 5, 2018 11:28 a.m.
When reading the groups or attributes of the CopySOP, it doesn't list any groups, is it possible for the CopySOP to read groups ?
Edited by _Christopher_ - Jan. 5, 2018 11:44:48
【T】【C】【S】
sepu
Jan. 5, 2018 11:45 a.m.
If you want to use the group later. Use the group transfer. The Copy SOP just read attributes. If you want to use a group for copy objects as I said use the target points.
Jan. 5, 2018 12:02 p.m.
@sepu What do you mean by target points ?
【T】【C】【S】
Jan. 5, 2018 12:49 p.m.
@sepu - That option isn't in 15.x
【T】【C】【S】
sepu
Jan. 5, 2018 12:58 p.m.
template group is called I believe in 15
Jan. 5, 2018 6:24 p.m.
I can't locate a node called template group; could it be groupCopy or simply doesn't exist ?
【T】【C】【S】
sepu
Jan. 5, 2018 7:07 p.m.
template group is on the Copy Stamp. Group Copy Sop it does that what it says, it copy a group from one stream into another.
