I'm trying to transform some points in a point wrangle and
vector vec = set(1,1,1);
@P += vec;
@P -= vec;
returns points to their starting position as expected, but
@P = point(0, “P”, @ptnum)+vec;
@P = point(0, “P”, @ptnum)-vec;
gives different results, as if the first transform didn't do anything.
why are the results different? am I using point() wrong? sorry if this is too common a question.
@P vs Point() problem
5728 6 1- xavier_h
- 4 posts
- Sean Rowe
- 39 posts
- xavier_h
- 4 posts
If that's the case, then why does
@P = @P+vec;
@P = @P-vec;
work the same way as the original
@P += vec;
@P -= vec;
yet acts different than
don't @P and point(0, “P”, @ptnum) do the same thing?
@P = @P+vec;
@P = @P-vec;
@P += vec;
@P -= vec;
- Sean Rowe
- 39 posts
They do mean the same thing, if you bound both ways to two new attributes they would match.
I think the reason that the top expressions work is because of the way code is read in general coding practices.
@P = @P+vec is recognised as @P += vec. The point expression being a vex function probably isn't recognised the same way.
- 8551 posts
you have to imagine it step by step:
the same goes for @P += and -= example as that's just the shorter syntax to the same assignment
but in here:
also worth noting that point(0, “P”, @ptnum) is pretty ambiguous andin this case Houdini makes a good guess you want to use vector representation, but if using within a longer expression and not just on it's own as a part of assignment it's safer to use vector(point(0, “P”, @ptnum))
vector vec = set(1,1,1); // imagine @P is {0,0,0} @P = @P+vec; // now you are altering @P to be {0,0,0} + {1,1,1} = {1,1,1} // so from now on @P is no longer {0,0,0} but {1,1,1} @P = @P-vec; // now you are alreting @P to be {1,1,1} - {1,1,1} so back to {0,0,0}
but in here:
vector vec = set(1,1,1); // imagine @P is {0,0,0} @P = point(0, “P”, @ptnum)+vec; // now you are altering @P to be {0,0,0} + {1,1,1} = {1,1,1} // so from now on @P is no longer {0,0,0} but {1,1,1} // however point(0, “P”, @ptnum) function takes P attrib from the input 0 so it will always return {0,0,0} // even after this point as it has no connection to @P @P = point(0, “P”, @ptnum)-vec; // therefore here you are setting @P to be again {0,0,0} - {1,1,1} so {-1,-1,-1}
- vusta
- 555 posts
I'm not technical so pls don't hang me for this…but I'll try:
if you use
@P += vec;
@P -= vec;
then you are using the updated pos in the wrangle.
if you use
then the point() refers to what you STARTED with before you got into this wrangle.
So use this test:
@P += vec;
printf(“y:%f\n”,vector(point(0, “P”, @ptnum)).y);
printf(“Py:%f\n”, @P.y);
and you'll see clearly @P inside the wrangle is updated…but point() is not using the @P inside the wrangle. It's using the orig input before any manipulation.
if you use
@P += vec;
@P -= vec;
if you use
So use this test:
@P += vec;
Edited by vusta - March 8, 2018 20:18:47
- xavier_h
- 4 posts
