Houdini on Ubuntu
   9169   14   3
Just build a new machine, installed new Ubuntu and Houdini.
But Im getting some issues with display and in general. When I run help window Im getting weird display failures. Like GPU is failing or completely freeze the whole system.
Edited by JozefPlata - June 3, 2018 17:21:17
JJ FX
Which version of Ubuntu are you using? The recommended one from SideFX is LTS 14. I find that Mint 18 had great support for Houdini
Houdini runs like butter on my Dell 7577 laptop with KDE Neon.
The only issue is when I first boot up and log in there is some visual glitches around the mouse. But if I log out and log back in it runs perfectly.
soho vfx
LLFA
JJ FX
Im running 18.04 LTS
The Proprietary Nvidia drivers, if you haven't already
I'm o.d.d.
goldleaf
Yeah did that too. And now I cannot even start Houdini. It completely freeze after splashscreen when the main window loads up.
Gonna try other distribution, as this might be an actual GPU failure. This is a brand new GPU card, so rather unlikely, but….
I am using it on 18.04 with Nvidia without problems. I am almost 100% sure you did not install these drivers correctly. What does it says in About section?
Edited by SreckoM - June 11, 2018 06:23:36
SreckoM
Actually I reinstalled new system as I might have done few things not the way I should. Because last time I upg the nvidia drivers in terminal. This time I did that in settings manually. And I managed to run Houdini.
However still sometimes I get some viewport glitches, and aftet that I get a crash. But this time at least there was a backup file created.
Right now I have just:
1) Installed Ubuntu
2) Did updates manually
3) Updated NVIDIA drivers manually. However still in About section the system shows me gpu type NV60 (or sth like that, im at work now) but I have GTX1060.
And thats it for now. Ive read that you need gcc too for houdini. Not sure what that is actually, but know how to install it from terminal.
Im rather new to Linux, always worked on Win.
No need to complicate so much.
First turn off Secure boot in BIOS. Did you do that?
When you say manually and terminal, what exactly does that mean? I install Ubuntu drivers by going Software updater and Additional drivers and check Nvidia proprietary.
No need for installing gcc, you have all that.
important thing is to turn off Secure boot.
Is it showing you “NVidia corporation” as the OpenGL Vendor? If not, you may have the open source drivers. I don't think I've ever seen the Nvidia proprietary driver display their GPUs as their codenames, only the marketing name.
I just installed Houdini 16.5.496 on Ubuntu 18.04 and I get a crash on launch.
I can still launch and use H16.5.378 just fine.
Any tips on how to get past a “HOM_OperationFailed” error?
Edited by Enivob - June 12, 2018 12:27:57
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
@SreckoM - I mean that I used Ubuntu settings tools for that. Ok when I get home will try disabling Secure boot in bios too.
@twod - will check that later tonight and will post you what I have
My issue was a 3rd party render system, Redshift was not compatible with the .496 release. Once I upgraded my Redshift to the latest version, which is matched to the H16.5.496 API, and altered my houdini.env to point to the new plug-in Houdini launched just fine.
This API mis-match could be an issue for Arnold users as well.
Ok so I checked today. And I have to say it finally recognize my GPU (GTX 1060). I might not have restarted the system after installing the drivers.
And the drivers Im using are proprietary Nvidia drivers. Exactly says:
Using NVIDIA driver metapackage from nvidia-driver-390(poprietary, tested)
Ive read about this Secure Boot and Im not so sure if I want to disable it now. Lets wait a day or two and see if I keep getting crashes and issues with viewport.
What does it says on About? As far as I know Nvidia drivers on Ubuntu will not work (at least not without issues) with Secure Boot enabled. Go to terminal and type nvidia-settings. Does it open settings window?
