I have an issue with Fluid Vertex Animation Texture. I am testing it using the source data from GDC2017, and exporting FBX and textures via Houdini 17.0.416 and Game Development Toolset 1.119 from Git, then import them into UE4.21.
Here is the picture what shows the issue I have. It looks like some vertices sampling wrong pixels of position map.
When I migrate Static mesh and textures from UE4 project file of GDC2017 into fresh UE4 project, it works. But if I export Static mesh as FBX, then import to fresh UE4 project, it doesn't work. So I am assuming something wrong with FBX importer in UE4.
Does anyone success to make Fluid VTA work in 4.21? Does it require to use any specific FBX import in UE4? Any suggestions are welcome.
Thanks,
Makoto
4085 6 0- Makoto Tanaka
- 4 posts
- mikelyndon-sesi
- 394 posts
- Makoto Tanaka
- 4 posts
Hi Mike,
Here is the screen grabs. I am just using default setting.
I didn't use “Use Full Precision UVs” when I import the static mesh, so I have enabled the option, then tried to import the mesh. But the tick mark of the option turned off as soon as I re-imported the mesh, so I am not sure the option is working properly.
Edited by Makoto Tanaka - Feb. 13, 2019 12:12:18
Framestore
- mikelyndon-sesi
- 394 posts
- Makoto Tanaka
- 4 posts
- mikelyndon-sesi
- 394 posts
I've tested the VAT shaders recently in 4.19, 4.20 and 4.21. Besides a minor issue with the naming of bounding_min and bounding_max the export works correctly.
I doubt the issue is UE4. It's most likely your import or asset settings causing the issue.
For the mesh, make sure to turn off “Remove Degenerates” and change Vertex Colour import to “Replace”
For the static mesh settings, make sure you've turned on “Use Full Precision UVs”
For the textures, change:
Compression settings to Vector Displacement
Power of Two Mode to None
Filter to Nearest
If you've done all of that and it still doesn't work, check your material instance settings to make sure your bounding values are correct.
Filter to Nearest
- Makoto Tanaka
- 4 posts
Thank you for the info. It is now working.
It seems that I just need to refresh the internal texture cache in UE4 after changing texture import setting.(I have cleared the texture slot in Material, and then re-assign it)
In my case, it works with HDR compression setting, and I can't find any visual difference between HDR and Vector Displacement.
Thanks,
Thanks,
Framestore
