Select primitives or edges by angle
31088 31 6- bobcat
- 41 posts
- Konstantin Magnus
- 670 posts
In the group node there is a tab called “Keep by normals”, where you can define a direction as a vector and a spread angle. Works for points, edges and primitives.
- bobcat
- 41 posts
Awesome, got it. Thank you.
But is there any change of getting something like 3Ds Max or Maya like select by angle?
This kind of works but not like I was hoping for. Trouble is:
1. you have to figure out the vector of the primitive (or whatever you are selecting)
2. it selects all primitives facing this vector and doesn't stop at angle treshold
I mean I see a way you could get around this but it starts to loose its efficiency.
- anon_user_37409885
- 4189 posts
- Konstantin Magnus
- 670 posts
I guess he wants the tool to select contiguous primitives only.
- bobcat
- 41 posts
OK, I made and RFE for this feature. So fingers crossed.
Artye
yes you are right, Spread Angle affects the selection. But as Konstantin Magnus says - I was thinking of something more like a contiguous selection which would stop whenever it encounters a certain treshold.
something like this
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-3BD433E9-2FC6-4DC5-9B4F-D8EBB2581C97-htm.html [knowledge.autodesk.com]
By Angle
When on, selecting a polygon also selects neighboring polygons based on the numeric Angle setting to the right of the checkbox. This value determines the maximum angle between neighboring polygons to select. Available only at the Polygon sub-object level.
For example, if you click a side of a box and the Angle value is less than 90.0, only that side is selected, because all sides are at 90-degree angles to each other. But if the Angle value is 90.0 or greater, all sides of the box are selected. This function speeds up selection of contiguous areas made up of polygons that are at similar angles to one another. You can select coplanar polygons with a single click at any Angle value.
Artye
something like this
By Angle
- Konstantin Magnus
- 670 posts
You could also try to develop that tool in python yourself.
Comparing angles could be remotely similar to this VEX code:
Contiguous neighbors can apparently be identified in Python, as well:
http://forums.odforce.net/topic/10441-nearest-connected-neighbors/ [forums.odforce.net]
And viewport selections can be read in, too:
https://www.sidefx.com/forum/topic/21922/?page=1#post-102109 [sidefx.com]
// compare user normals against surface normals float compare = distance(@N, normal); // assign to group if within threshold if(compare < threshold){ setpointgroup(0, "angle_select", @ptnum, 1, "set"); }
Edited by Konstantin Magnus - Feb. 27, 2017 19:08:19
- bobcat
- 41 posts
- NERVAGON
- 6 posts
- 4189 posts
- NERVAGON
- 6 posts
@Artye I don't understand exactly the operation you are trying to do, but if you want to operate on groups of faces by edge angle use facet node using Cusp Angle. Here I have done a poly inset by edge angle with just 2 nodes.
Apologies if this is not they answer you need. I have only been a Houdini user for a few days.
Edited by NERVAGON - March 1, 2017 15:02:49
- 4189 posts
- bobcat
- 41 posts
I absolutely got my answer for what I asked. Thank you for the tips guys. But I just realized I have phrased it all wrong. My bad. What I had in mind.
Can you select these polygons with one click?
You just click once on one primitive and the selection continues until it hits a certain angle treshold. In this example it could be anything from 0 up to 89.999.. I know I could do it manually and there are great valid ways to do it. But applications could get more complex, this is just to demonstrate what I am looking for.
This is the feature I am looking for.
https://www.youtube.com/watch?v=LWvgWrTMdAs [youtube.com]
- nisachar
- 83 posts
bobcat
Might not be with one click, but creating groups by edge angle is possible. The box example above suggests a way to determine the direction of your selection along with edge angle.
Might not be a click and select method, but you can combine selection methods in a group ( and do further modification to that selection bu using other groups that act on the incoming selections ). One advantage is that since it is automatic, any change to the incoming geometry will reflect in the group's selection and pass the info further up the stack.. Err.. down the Network.
Edited by nisachar - March 2, 2017 19:44:44
- bobcat
- 41 posts
- nisachar
- 83 posts
- awesomedata
- 17 posts
- jerry7
- 626 posts
- awesomedata
- 17 posts
- 4189 posts
