How to set "Non-Zero Exit Code Handling" on Local Scheduler?
   1731   2   1
I am using a ropfetch TOP that I was hoping would automatically reschedule a failed mantra render task, but it has left it as ‘failed’. The H18 manual entry for Local Scheduler has a section for “Non-Zero Exit Code Handling” but I can't find any of these parms on the Scheduler. Is it possible to auto-reschedule failed tasks?
/ken_jones/$: _
This feature was added to 18.0.302. If that's what you're running, you can override this job parm on your TOP node by adding the scheduler job parm override: https://www.sidefx.com/docs/houdini/tops/schedulers.html#override [www.sidefx.com]
Gotcha, I was on 287. Thanks!
/ken_jones/$: _
