I am using the houdini engine with 3ds max and getting the following error when starting a session: "Could not create session with pipe name: Could not create session with pipe name: HEMAX_AutoPipeServer"
it works when i start max with admin rights. it seems with admin rights the pipe can be opened. but when starting max with normal rights i get that error. someone has an idea, how one can resolve this?
another question is how do you propagate a selection in max (edge selection) to the hda. it does seem not to work, the hda modifiers works on the whole object and not on subselection level. any ideas? thank you.
max houdini engine start session error
6718 5 0- houGenie
- 22 posts
- houGenie
- 22 posts
- BrookeA
- 387 posts
Hi there,
Can you submit a bug for the problem with the session not successfully starting when not using an administrator account? A bug can be filed here: https://www.sidefx.com/bugs/submit/ [www.sidefx.com]
Thank you!
Thank you!
- houGenie
- 22 posts
BrandonAIt would be interesting to know if it is correct, that the admin rights are must have. or if some ppl can successfully use houdini engine with normal user. i mean it could be something on my end, who knows.
Hi there,
Thank you!
- houGenie
- 22 posts
- vusta
- 555 posts
