https://www.sidefx.com/docs/houdini/nodes/lop/pythonscript.html [www.sidefx.com]
however when I try to use GetPath() I get python errors saying object has no attribute GetPath.
I'm assuming the way I am referencing is wrong hence it can't ‘see’ it?
# Add code to modify the stage. # Use drop down menu to select examples. from pxr import UsdGeom node = hou.pwd() stage = node.editableStage() #cube = stage.GetPath("/obj/Set_EXR_FileNames/lopnet1/CHECKPOINT") cube = stage.GetPath("/sopimport1/mesh_0") # Change attributes directly #cube.GetAttribute("size").Set(3.5)
