Procedural way to group revolve divisions
1682
5
0
- Josephbt
- 3 posts
Hey all,
is there a easy procedural way to group the revolve divisions? I already tried include by edges / min edge angle, but this works not with every form.
The other idea was to create a reference copy and change the surface type to columns to transfer the edges somehow?
Best, Joseph
vase.hipnc (113.1 KB)
- Aizatulin
- 475 posts
you can try to use the division count as offset value, to get the next neighbour point, which should be the edge (together with the
source point).
vase_group.hipnc (123.7 KB)
- vusta
- 555 posts
or rethink ?
- in revolve, don't enable end caps
- no need for blast, see above
- bevel, as is with Ignore Flat edges>Normal angle ~20ish
(ie. no need to group the edges manually, clear your selection out entirely!)
simples.
ahhh, sorry you need the bottom, of course…enable end caps back on
Edited by vusta - May 20, 2020 18:59:41
- Josephbt
- 3 posts
vusta
or rethink ?
simples.
Hey Vusta, thank you but already tried this method, this wont work for any form.
Edited by Josephbt - May 23, 2020 11:30:34
Anmerkung 2020-05-23 172713.png (535.5 KB)
- vusta
- 555 posts
Josephbt
vusta
or rethink ?
simples.
welllllllllllllllllllllllllll I will not admit defeat…..there's always DIY !!!
here…I modded the Revolve so that there's an edge group called xsection, then you can bevel this group.
go ahead, change the revolve Divs til the cows come home…will still work.
vu_Revolve_mod.hiplc (157.3 KB)
- Josephbt
- 3 posts
vusta
Josephbt
vusta
or rethink ?
simples.
Ahhhh! Perfect, Thank You!
