Hey SESI,
RFE: It'd be useful to be able to sort by various columns in the Details View Pane.
ie. The usual GUI behaviour: you click on a column header and all the rows are sorted by that column. Clicking on the Point Number column would reset the sorted order to the usual numeric sequence.
cheers,
ben.
RFE Sort columns in Details View Pane
7744 10 2- ben simons
- 387 posts
- rvinluan
- 1256 posts
ben simons
Hi Ben,
That's a great idea.
But instead of LMB-clicking on the column header to sort, how about the user RMB-clicks the header and a menu pops-up with a list of options for sorting (i.e. “Sort Ascending”, “Sort Descending”, etc.)? At least that way, the functionality for selecting all the entries in a column is preserved.
Rob V.
- digitallysane
- 1192 posts
I think the general accepted UI habit is to have it sort in one way when clicked (for example ascendent) and then reverse the order when clicked again (to descendent). Maybe double-click for selecting the column?
I think it comes down to which would be the most used action: to select or to sort?
Dragos
Dragos
- ben simons
- 387 posts
- digitallysane
- 1192 posts
- stevenong
- 1631 posts
- ben simons
- 387 posts
- rvinluan
- 1256 posts
digitallysane
Yeah, a few other people I've talked with also like having to just click the column header to sort as opposed to using a RMB menu. I'll update the RFE to note this.
digitallysane
Dragos
I don't have an answer for this. But this thread suggests that sorting seems to be the more popular choice
–Rob
- rvinluan
- 1256 posts
ben simons
Oh.. Yes. ops: But I was using Houdini 8.1 ;-) Coool.
btw: what's the use in selecting a column?
Can anything be done with the selection?
Honestly, I'm not sure how useful it is for selecting a column in the Details View. My only idea is when you want to quickly reset the values of a point/prim/vertex attribute. So in that case, you would select the column, change the value in the floating input field and presto, all the values in the attribute column are updated.
– Rob
- mtucker
- 4441 posts
I would tend to think that sorting is a far more common operation than selecting for columns. In some cases, such as the DOP Details View, the whole idea of selecting a column doesn't make any sense because you can't do anything with the selection once it's made. So I would think having “select column” under the RMB menu (or maybe even using double-click if that eliminates the RMB menu completely) and sorting with the LMB would be more useful.
Mark
Mark
- pbowmar
- 7025 posts
I agree, once Attribute CReate came along, it's been much easier to reset attributes procedurally (i.e. correctly) rather than selecting a column in the spreadsheet and then pow, your SOP is locked. I can't remember the last time I had to lock a SOP except to prevent cooking.
The exception is in the Edit Capture Weights spreadsheet, I select columns all the time in that, and not sure how useful sorting is in there generally, though it certainly might be.
Cehers,
Peter B
Cehers,
Peter B
