I´m having problems with copy2points in LOPs when copying spot lights.
There is an animated “N” attrib controlling the direction of the light. In the viewport It seems fine, but when rendering, the direction of the light flickers.
I´ve done the same thing using the Point Xform and the render behaves like the viewport, so I´m thinking this is a bug. Can anyone confirm It?
Anyway, is this approach fine? Does It have a big performance hit while creating primitives when compared with just changing their attributes?
Copy2Pts x PointXform [Bug] [SOLVED]
3752 10 1- guilhermecasagrandi
- 263 posts
- 7768 posts
- 263 posts
jsmackYes, and the copy2points behaves the same in the viewport, only in the rendered images It behaves differently.
That's really strange. I modified the pointxform side to see if putting the transform on the reference instead of the light produced the same result but it was still normal. The matrices are slightly different, but only after the 5th or 6th sig fig.
- 7768 posts
- mtucker
- 4438 posts
If you look at the “Local to World Xform” of the light coming out of the Instancer LOP using the spreadsheet view, you can see that it's generating small non-unit scale values (the scale coming out of point xform is exactly 1.0). Even if I turn off “Set Scale” in the Instancer LOP. I'm hoping that's where the discrepancy is coming from, but I'll need to do a bit more digging to figure out why it's ending up with scales in the xform… I'll let you know when/if I make any progress.
- 7768 posts
mtucker
is it a karma bug that 0.1 % scale would cause the spot light size to vary that much?
- mtucker
- 4438 posts
The bug is that there is any scale being set at all. This is happening because we are doing some internal orientation calculations at half-float precision in the Instancer LOP. This problem will be fixed in tomorrow's build.
I don't know how to judge if karma is responding “correctly” to these scale values…
- 263 posts
mtucker
Thanks again!
At least in the flipbook, I don´t see the scaling effect, only in the render (with Karma).
- 7768 posts
mtucker
I did some tests, and karma seems abnormally sensitive to these scales, although I wouldn't expect scales to affect the spot light effect at all.) A scale of as little as 0.1 % is enough to make the spot radius 10x larger.
- brians
- 468 posts
- 263 posts
