thank you
as later assignments overwrite previous ones
that's exactly what i have the biggest issue with. As you will have one object living in several materials without actually knowing it. So you will reassign object to materialA, you will wonder why its not working and then you realize that some other material down the line is actually overwriting it. and then you might realize that there is actually another material that overwrites it again. with 150 materials, its impossible to fix those without lot of effort.
Which makes it nightmare to work with, thus why i want to create unique groups/collections/what ever that does take care of this duplicity. If it makes sense
how to assign to groups rather than Xforms in Solaris
16001 46 6- martinkindl83
- 260 posts
- 7803 posts
- martinkindl83
- 260 posts
Groups and collections can have overlaps, that's why i have build my custom node that creates groups and takes care of duplicity (and i want to build same tool in LOPs operating on collections (or what ever i decide to be suitable)).
with materials where the last one wins, look at my example.
In first step i assigned Bucket being blue and Rope being green and Screw being red.
In next step i realized that my assignment is wrong and that Bucket needs to be Red as well, so i do drag and drop my Bucked onto red, but it will still render blue. I have to also go and manually remove it from blue assignment. On lot of materials, this is impossible to do.
Edited by martinkindl83 - Nov. 11, 2020 21:20:50
- martinkindl83
- 260 posts
Best how to describe the workflow im after is ShadingGroups in Maya (Im not maya person, but its easier to explain). ShadingGroup represents material, and one object cant live in multiple ShadingGroups.
So i create my shadingGroups (red, green, metal) and then i start drag and dropping objects onto those groups in Outliner.
Based on in which shadingGroup the objects is, it will get material. If i decide that objectA should not be red, but metal, i simply drag and drop it from Outliner to shadingGroup metal and it will have metal material, even though it was red before.
- 7803 posts
martinkindl83
Create a new node when changing the assignment. This will eliminate the need to edit multiple assignments just to change one.
- 7803 posts
martinkindl83
That's exactly the same as material assignments in USD. A prim cannot have more than one assignment.
- martinkindl83
- 260 posts
sorry, but thats even worse in my opinion
as then you will not just to have dig through all the material tabs on one node, but even through multiple material nodes.
I know its possible, but to me it creates even bigger mess to work with. As you will not be fixing the problem, where it occurs (material node it self), but rather create bunch of overrides to hide the problem. Thats my opinion, in no means im not saying your suggested workflow is bad and mine is good, to be clear.
- 7803 posts
It makes sense for edits to be enumerated rather than trying to find what you did upstream and figure out what needs to also be changed on the node for the change to work. Using a separate node for edits also gives the opportunity for writing notes about what was changed.
Adding another entry at the bottom of the same material assign also works as it takes precedence over the higher entries. If I had dozens of assignments on the same node, I wouldn't want to try to track down which entry contained what widget if it's faster to add an entry to the bottom or create a new node. The end result is what matters, not the list of edits.
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
- rafal
- 1449 posts
- jerry7
- 626 posts
martinkindl83
You could drag material from the scene graph and drop to prim in the viewport. Drag/drop to viewport can keep material assignment only once.
But I can't find a method to drop to multiple prims at one time.
Edited by jerry7 - Nov. 12, 2020 19:48:33
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
rafalOne question from complete different field.
Another potential workflow is to use an attribute on a primitive to determine the material. See attached example.
What would be the best equivalent to geometry spreadsheet in LOPs?
If i would want to inspect material on your instances, i would check geometry spreadsheet and i would see all the values on all prims.
I havent found a simple solution to do the same check in Lops.
I only found: select all the instances in the Composed Scene Graph (not very handy to be forced to select them) and then Scene Graph Details and change it to List View.
M
- rafal
- 1449 posts
Scene Graph Details in LOPs roughly corresponds to the geometry spreadsheet in SOPs, so I think you are on the right track.
One suggestion for selecting prims in the Scene Graph Tree: at the bottom of the tree there are two collapsed UI gadgets: filter and selection rules. You can use these to search for your instances to make the selection easier.
- martinkindl83
- 260 posts
rafal
Thank you, thats super handy.
- Soothsayer
- 861 posts
- martinkindl83
- 260 posts
- Soothsayer
- 861 posts
martinkindl83
Get the file above. It has it as one of the exapmles I believe.
Yes, but it hardcodes the material paths like so:
if( s@foo == "a" ) return "/materials/green"; else if( s@foo == "b" ) return "/materials/blue"; else return "/materials/red";
But I want to do something like
return s@shop_materialpath;
Where s@shop_materialpath is an attribute on the geo itself. I don't really get LODs yet. It only considers usd attributes that exist on usd prims, right? It seems like there should be a simple way to grab the paths from geometry prim attributes. I'm sure there's just a tickbox somewhere but I can't for the life of me figure it out.
Jobless
Jobless
- 7803 posts
Soothsayer
shop_material path is unlikely to point to a usd location, unless it's been constructed manually in sops with hypothetical usd locations in mind.
A more plausible use would be to take the shop_materialpath attribute and manipulate the string to get at part of the path, and then concatenate this with a usd location containing one or more materials.
