Have 1 Edge of A circle Polygon always point to -z?
   3362   6   1
Hello so i`ve been trying to figure out the math
(or another hacky solution.)
To make one Face always point to -z ( the face is sometimes the avg of 3 or 4 faces 4.)
Edited by NicTanghe - March 10, 2021 10:29:27
TEmpleExFin.hipnc (523.6 KB)
here, set up your foundation like this so that prim 0 will ALWAYS face Z, no matter how many sides there are in your foundation.
(I picked Z instead of -Z...just easier to see for me, same difference)
Edited by vusta - March 10, 2021 15:33:43
vu_FaceZ.hipnc (73.7 KB)
How did you arrive at that formula ?
Btw thx u a hero.
NicTanghe
Btw thx u a hero.
just worked it out on the fly i think...so a circle is just an identical segment being incrementally rotated until it perfectly joins
back on itself so i started with 360/N...that didn't quite work out so i simply tried 180/N...that magically worked with one side constantly facing X direction, then it's a simple case of offsetting by 90...so really didn't set out with any fancy formula in mind, just do something...see something....then deal with it.
You can rotate an edge to an axis with:
int pts[] = expandedgegroup(0, 'single_edge');
vector pos_0 = point(0, 'P', pts[0]);
vector pos_1 = point(0, 'P', pts[1]);
vector dir = normalize(pos_1 - pos_0);
matrix3 rot = dihedral(dir, {1,0,0});
v@P -= avg(pos_0, pos_1);
v@P *= rot;
edge_to_axis.hipnc (235.6 KB)
Domo arigato gozaimasu.
SO i tried to change the setup with adding a extra vertex to so it takes the edge that goes from the start of 1 edge to the end of another.
and adjuster the code to int pts = expandedgegroup(0, 'single_edge');
vector pos_0 = point(0, 'P', pts);
vector pos_1 = point(0, 'P', pts);
v@P *= rot;
this did not immediately work.
I will do more testing tomorrow and then be back. But i don't c why it doesn't work. I also do not exactly understand what expandededgegroup actually does.
or does it indeed just appoint the edges new numbers from 0-1 ?
Edit it seems in my example and basically when aplying a hacky way is just to resaple the edge to 1 edge.
Edited by NicTanghe - March 17, 2021 09:13:11
