Crash on Launch
   3770   6   0
Hey
Fedora 35 machine running Houdini 18.5.351 Python2 Indie.
Crashing on launch
free(): invalid pointer
Aborted (core dumped)
Also crashing when launching license manager, hkey
Double free or corruption (out)
If I try to run hython on terminal:
No licenses could be found to run this application
Please check for a valid license server host
14162 ThreadId=0x7f7260fff640:
14162: (sent by pid 14162)
Unsure what is the source if Houdini Licensing itself or operating system, since there's also mention of:
libc.so.6 libHoudiniUT.so libHoudiniPRM.so
Anyone faced this before? Last cry for help before reinstalling everything, eheh.
Edited by probiner - Dec. 13, 2021 13:53:48
Make sure you have all the required packages installed.
libxkbcommon-x11, libxcb-icccm4, and libxcb-render-util packages required for Linux users
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
jsmack
libxkbcommon-x11
Installed
jsmack
Can't find their Fedora releases. Is this a Debian Ubuntu only requirement?
Will check some of the other libraries mentioned.
probiner
jsmack
libxkbcommon-x11
Installed
jsmack
I found the equivalents here: https://fedora.pkgs.org/35/fedora-x86_64/xcb-util-wm-0.4.1-21.fc35.x86_64.rpm.html [fedora.pkgs.org]
and here: https://fedora.pkgs.org/35/fedora-x86_64/xcb-util-renderutil-0.3.9-19.fc35.x86_64.rpm.html [fedora.pkgs.org]
However I am getting this same message:
free(): invalid size
19 worked on Fedora 34 but seems to have broken on Fedora 35? 18.5 is working fine.
Anthony Morrelle
Hired Gun
Anthony Morrelle
probiner
jsmack
libxkbcommon-x11
Installed
jsmack
Oh darn... I was thinking it was some silly user error here. Maybe there's something more to it. I did up just going ahead and installing Pop!_OS... Will give Fedora another try, another time. Cause updates have been giving me some unstable experience recently.
Issue was reported to support, if more info comes out of it, I'll post.
Adding this in case any other Fedora users are lost.
I thought I'd put in a ticket too. They had me run this preload command:
export LD_PRELOAD="/lib/x86_64-linux-gnu/libc_malloc_debug.so.0"
That doesn't work on Fedora because that shared object is in a different folder. The command for Fedora is:
export LD_PRELOAD="/usr/lib64/libc_malloc_debug.so.0"
Now all is fine again.
Anthony Morrelle
Hired Gun
Anthony Morrelle
Thanks for sharing!
