MaterialX online library
   20976   31   9
Hi.
I just came across AMD's online library to download/upload MaterialX materials.
https://matlib.gpuopen.com/main/materials/all?category=Plaster [matlib.gpuopen.com]
Best
Mark
Mark Wallman
Hi.
Best
Mark
They don't seem to be compatible with solaris. I tried one, and it uses a nodegraph defined node, which solaris can't seem to see into, so the material appears as a gray shader.
Oh dear. There was me hoping materialX would work through different apps. I hope these are just issues because it is so new best
Mark Wallman
It seems like Solaris doesn't really support materialX at all. Sure it can use the base nodes as a shading graph for karma, but if it can't decode nodegraphs, it's not much use for interchange.
I would think that this is just a bug, or some unconventional thing going on.
Edited by jason_iversen - Dec. 21, 2021 17:41:23
jason_iversen
It's nodedefs that aren't working. I'm not sure if it's a bug or just a feature that's not implemented yet.
We'll definitely be looking into these issues early in the new year. Right now most of us are on vacation, so please be patient. While that AMD library of MaterialX materials was hugely exciting, the timing didn't give us much chance to respond to the issues that cropped up.
Happy holidays!
Technically how to import .mtlx into houdini?
w007s
Import the .mtlx file as a reference in Solaris. It will then show up in the Scene Graph Tree and you can assign it to geometry.
BrianHanke
So import?
ScreenRecorderProject51.mp4 (1.9 MB)
w007s
BrianHanke
So import?
Yes, import it just like any other USD file. The materials are not different from materials created with a material library. They still have to be assigned correctly to work. In your video, you've assigned a blank prim, "Shaders". The materials under "Materials" are the prims to assign as materials. The "Shaders" prim is purely for organization and cannot be assigned.
Did you manage to get this to work? I've downloaded the Marble_Verde_Guatemala_Slatted material and used a reference node to bring it in to lops. When I try to assign it to a sphere and render in Karma though it doesn't seem to work. I'm assigning the MaterialX_Graph material, under Materials. Am I doing something wrong?
(using Houdini 19.0.455 apprentice)
Screenshot from 2022-01-05 15-44-57.png (55.5 KB)
Screenshot from 2022-01-05 15-46-10.png (53.0 KB)
Hi. Not yet. Sorry.
The dev team is currently looking into this and hopefully will have some answers for you soon.
mark
It looks like there's been an update to the AMD MaterialX library. The materials work a lot better in Solaris out of the box now. You should be able to just load them up using a File LOP. There may be some organizational things like paths to textures or shader names which might need some slight adjustment, but the materials are now way more compatible with Solaris.
Thanks Mark!
mark
mark
Mark, what version of Houdini are you using for this? I'm on 19.0.498 (Python 3) on Linux Mint and when I load as you have done above, I get the following error messages:
Error
Unable to find layer file: /home/dave-linux/Desktop/DOWNLOADS/CarPaint_SingleColor_4k_16b/CarPaint_SingleColor.mtlx
Warning
Failed to load plugin 'usdMtlx': libOpenGL.so.0: cannot open shared object file: No such file or directory in '/opt/hfs19.0.498/dsolib/usd_plugins/usdMtlx.so'
Warning
Warning
Cannot determine file format for @/home/dave-linux/Desktop/DOWNLOADS/CarPaint_SingleColor_4k_16b/CarPaint_SingleColor.mtlx@
/opt/hfs19.0.498/dsolib/usd_plugins/usdMtlx.so definitely exists, not sure why it's complaining about that.
It's not usdMtlx.so that is missing, it is libOpenGL.so.0 (which is used by usdMtlx.so) that is missing. That is a system library, which I believe you can install (depending on your Linux distribution) with a command like:
sudo apt-get install libopengl0
Hamilton Meathouse
Are other mtlx files working, such as the one of the examples in the HFS? That material is working for me, although I haven't tried it with 498. (I'm on 505) I've noticed a few of the materials have errors, such as missing textures or disconnected inputs, but so far it hasn't caused karma to reject them.
Hello
Is there any way to edit the materialX (import via FILE) in order to modify it?
In advance a BIG THANK YOU
Best regards
JY
Edited by JYA - Jan. 25, 2022 12:06:26
Import edit.jpg (1.1 MB)
