Attached a simple stage here with a root prim set to
assembly
+ a few different primitive kinds below it: subcomponent
, component
and group
. As expected, the
subcomponent
doesn't give any Draw Mode options in the UI while the component
and group
models do. Setting the Draw Mode to Bounding Box only works on the component
though. It was my understanding that if a group
prim had extents defined somewhere in the hierarchy it could display a bounding box, but maybe this is incorrect? The second question comes when setting the parent
assembly
Draw Mode -- in the UI it automatically toggles the descendant prim Draw Modes to match, but there is no effect in the viewport. Is this a bug, or is there some other step required to set up Draw Mode inheritance?
