Identifying the active input in a switch with many inputs
1328 5 0- element33
- 76 posts
I have a switch SOP with a whole bunch of inputs. The input index is defined procedurally, by an expression. I can see the index, but how can I quickly identify the currently active input node? Right now, in the parameters dialog for the Switch SOP, I use the index to count down the list, to find the name of the active SOP, but it's tedious. Is there some "Identify currently active node" function that would do this for me?
- animatrix_
- 4544 posts
You can use the opinputpath expression on the Switch node for example:
opinputpath(".", ch("input"))
- element33
- 76 posts
- 8624 posts
- element33
- 76 posts
- element33
- 76 posts
I'm using opinputpath(".", ch("input")), but here are a few findings from my research:
1) Alt-LMB on the Switch SOP lets you select an input wire by index (ready to rewire), but not the input node.
2) RMB on a wire lets you select its input/output SOP.
Sadly, I don't see a way to combine 1) and 2) into one desired operation "Select input on wire number 7"
3) With the first input SOP selected, Shift-PgDn steps through the inputs in sequence (in case I want to count)
As far as making the active wire more distinct: I see many config files that reference the appearance of network wires (list below), but it's tedious to change a value, then restart Houdini to see if I made a desired change.
1) Is there a searchable documentation on all such config files saying exactly these variables refer to?
2) Can Houdini "source" (re-read) all its config files in-session, so I can see the changes without a restart?
$HFS\houdini\default.wirestyles (I don't know how to define the appearance of a wire theme/style)
$HFS\houdini\config\NodeGraphLight.inc
$HFS\houdini\config\NodeGraphCommon.inc
$HFS\houdini\config\UILight.hcs
Edited by element33 - Nov. 15, 2022 09:33:32
