if (@primnum>0) removeprim(0,@primnum,1);
Leave only the first prim in a prim group
839 3 0- element33
- 76 posts
In a prim group, how do I remove all prims except the first one? I tried a Prim Wrangle, with the desired group in the "Group" field, like so:
But it removes all prims in a group (seems like @primnum starts at 0 for the entire geometry, not for the desired group). I can Split-SOP by group, then remove all prims but the first one, then merge back all geometry, but I'd like to do this without splitting. In a Prim Wrangle, I can also iterate through all prims, check group membership, save the first prim and remove all others, but maybe there's a way without iterating through all prims.
Edited by element33 - Nov. 22, 2022 19:20:01
- 8624 posts
- element33
- 76 posts
- animatrix_
- 4544 posts
If you want the fastest performance though, I would recommend doing this using the Blast SOP with this expression:
If you want to do this for an arbitrary number of groups, then I would gather all the first elements into an array using a Detail Wrangle, turn this array into a space separated string and then use that with Blast SOP.
`arg(primlist(0, "myprimgroup"), 0)`
