hello guys!!
Recently I'am working on water breaching effect in Houdini 15. And for post process I want to combine ocean grid and flip Simulations so that it looks seamless in all sense, I don't know how to do that so if anybody knows any kind of seamless method please do tell me.
looking of help!!
Flip and ocean surface merge
5161 4 1- nachiketkadhe
- 23 posts
- Olaf Finkbeiner
- 323 posts
It is sort of possible. But not straigh forward at all.
I helped with the setup here: https://vimeo.com/150886395 [vimeo.com]
The issue is that the
ocean waves has a cool procedural shader that uses UV Atttributes and point velocity etc.
A wave layer tank does not have that by default.
It is quite a while ago that i did that, and looking at the old scene i cant fully figure it out what i did.
I made sure that oceanspecturm has the same values both ion the waves and in the wave layer.
And i turned on Point Velocity and UV Attributes in the ocean_render/preview (ocean evaluate) Geometry tab.
Now one issue is that the nice shader from ocean waves does displacements and ocean waves does not need displacement…
It will never 100% fit but it was good enough for us at the time.
I hope this helps. Sorry for being vague but this was over a year ago when i did that.
kind regards
Olaf
kind regards
Olaf
- nachiketkadhe
- 23 posts
- Olaf Finkbeiner
- 323 posts
the aim is to “sync” the waves from ocean surface (which are purely generated not simulated) with simulated water.
With the wave tank you have without a boad almost the same waves as with ocean surface. This gets distubed by the boat or whatever.
Ocean surce with the ocean surface shader produces foam by displacement. In a wave tank flip simulation the foam is particles.
hope this makes it a bit clearer.
kind regards
Olaf
kind regards
Olaf
- Pavini
- 27 posts
