Calculate slope for attribute
868 10 2- _Christopher_
- 766 posts
I was hoping someone can help. In the attached image specifically near the end of the screen cast there are areas of light green. I'm using a maskbyfeature sop after a DOPImport to get these color values.
How do I calculate the angle of the slope of the areas which are green and create an attribute on those areas while having control over the angle of the slope of those areas as the maskbyfeature creates a float attribute. In other words, if the slope attribute is too steep; and it's calculating the slope around those green areas then don't create an attribute for those areas otherwise create the attribute for those areas ?
【T】【C】【S】
- 8583 posts
- _Christopher_
- 766 posts
- rafaels
- 696 posts
Those "ugly edges" seem to be consistent with your original data set.
You could paint a mask along the sides to filter them out...
Toronto - ON
- _Christopher_
- 766 posts
- rafaels
- 696 posts
Feed your geo into a bounds SOP;
Group the top and/or bottom faces of the box using the normal direction and delete them;
Use the ray SOP to calculate the distance from your geo to the bounding box's sides;
Attribute remap the distance value to your liking and multiply the resulting attribute by the slope.
OR
attribute paint a mask!
OR
Toronto - ON
- _Christopher_
- 766 posts
rafaels
OR
I have to create two groups, based on the normals (keep by normals) enabled; then I have to set one vector to 1, the other to -1 for each group create sop. Too bad one cannot do this in one group create instead of two.
Then using raycast sop, I cast the rays against the deleted primitives and the maskbyfeature node and this is where I don't see any results before feeding into the attribute remap distance sop ?
【T】【C】【S】
- rafaels
- 696 posts
Sorry, I didn't have Houdini near me when I first wrote and then I've been too busy to check back on this.
I'm attaching an example file of what I meant, only I'm using curvature instead. Hope it helps!
Edited by rafaels - April 5, 2024 16:14:52
Toronto - ON
- _Christopher_
- 766 posts
rafaels
Cheers,Image Not Found
The scene helps but in my case I'm using a DOPImport and it's not translating this is my node graph hoping it helps as I'm not seeing any results from the dist attribute ?
【T】【C】【S】
- rafaels
- 696 posts
_Christopher_
Switch the order of the nodes going into the Ray SOP. What I sent you was a potential solution for the "ugly" edge artifacts you mentioned here [www.sidefx.com], nothing more.
Toronto - ON
- _Christopher_
- 766 posts
rafaels_Christopher_
I did switch the order based on the graph seen above I placed the right side into input1 of the raysop and the left side into input2 of the raysop; it still is not recognizing the dopimport in relation to my original question as there is not values for the dist attribute.
Edit
What I think the issue is that ray sop does not work with dop imports it doesn't know how to calculate the hit attribute. Unless there is way I'm guessing that I have to cache it out ?
Edited by _Christopher_ - April 7, 2024 17:25:55
【T】【C】【S】
