APEX: Transform Object per primitives in group
   977   10   3
Hi;
I'm trying to read grouped primitives on the incoming Base.shp stream in an Apex Graph SOP that is connected to an ARC-Fuse SOP and create Transform Objects per primitive in the group; ie. if there are 6 primitives in the group, I want to create 6 Transform objects.
I looked for a relevant Apex Graph node that outputs the grouped primitives as an Array that I wanted to iterate over but to no avail :-/
What I ultimately (hopefully) aim to accomplish is to create n number of Transform objects per prims in a prim group and constrain them to the center of each primitive in the group via the primconstraint node. This I need to do within the bounds of APEX. not upstream of it, as the generated joints need to be constrained to the prims post-deformation.
Any help would be wildly appreciated.
Cheers;
AJ
Edited by noc2 - Feb. 1, 2026 19:34:21
Can't you use geo::ForEachPrimBegin/End to loop over the primitives of your group?
Hi Edward;
Yes, therein lies my wee problem I should be doing something wrong, bu can't quite wrap my head around what it may be
Here's a screenshot from my test scene. I expect 2 transform objects to be created as there are 2 prims in the group that is being iterated over yet a single Tr objects is being generated. What do you think I'm doing wrong here?
Edited by noc2 - Feb. 2, 2026 11:41:46
Ah but you can't do it this way because the number of controllers in a rig is not procedural at animation time. You would need to create these controllers in your component as part of the rig itself.
edward
Ah, so there it is! Thank you Ed, much appreciated! So, I take it that what I need to do is to do this using a component script. Should I do so before deformation is computed or after you think?
Your component shape modifies the rig procedurally so it will just put these controllers in a place that feeds into the bone deform. So doing it in the place where you currently have it in your screenshot works. It's just that you cannot use the graph fuse workflow for this.
Hi, here is a component script that will set up a control per prim in a group and then constrain it to the prims, post bonedeform.
Hope this helps.
controls_on_prims.hip (577.2 KB)
william_harley
Hope this helps.
This nothing short of pure gold William! Thanx a million! I am studying it atm and I'm sure it'll open up so many doors for me (Your master class already did btw)
Lotsa cheers;
AJ
So now here's another challenge that I couldn't get over Let's say that these generated ctrls are supposed to deform certain packed geometries that are close by their positions. How is that possible to accomplish? Since the ctrls are generated through a snippet, the geometry can't be fed as captured packed geo upstream.
Every step forward yields a completely new enigma in and of itself
Edited by noc2 - Feb. 4, 2026 16:28:46
It might be a little easier to help if you frame the problem rather than a step by step approach.
What do you want to achieve, what is the goal
william_harley
Hi William;
My ultimate goal was to get the generated transform objects to capture geometries who are positioned almost exactly where the said transform objects are generated. Since the transform objects are generated through a snippet, this needs to happen after the generation.
I just wrote back and forth with support and I can see that the most practical way of getting this done is to separate these objects manually and feed them as separate .shp streams and use a setpointtransform per generated transform object to get them to be moved. In the case of a high number of geos to be affected by each relevant transform object that kind of promises to be quite an extensive network :o
Imagine little spheres that are positioned above the primitives your snippet uses to create transform objects. I wanted each transform object to set point positions for the nearest sphere.
Edited by noc2 - Feb. 5, 2026 15:13:46
