Is there any "Skew" deformer in Houdini?
   4810   4   2
Hi;
Is there any “Skew” deformer in Houdini (like other 3d software)?
Thanks.
Edited by Masoud - July 22, 2019 09:47:48
Masoud Saadatmand (MSDVFX)
Wouldn't applying a matrix be sufficient? “Rotation” basically is skewing “done well”.
Marc
Good bye.
Transform SOP has Shear parameter, would that work for you?
CG Supervisor
Framestore, NY
I'm pretty sure, that (once) shear was a part of the twist sop.
But the transform sop will do the job for sure.
If you want similar behaviour like 3ds max or something, I would prefer an attribute wrangle. If you have a center an axis and a direction, which is perpendicular to the axis you can use this to capture the geometry to get local parameters.
For each point a local translation can be performed, depending on these parameters. Adding few ramps can give more control over the local direction / amount for example.
Here is an example …
shear.hipnc (74.5 KB)
tamte
under my nose for 14 years... never used it, my brains literally blocked it out. Thanks. And i was going to manually deform and blend to get there... :$
