XPU shader pre-compile issues
2047 23 2-
- brians
- 626 posts
Following on from a now-closed H22 beta post regarding XPU shader pre-compile issues:
It has been pointed out that the H22 XPU shader pre-compile feature is running extra slowly than H21. 22.0.398 contains a fix that would have affected multi-GPU users. For anyone affected by the H22 issue with multi-gpu, it would be good to get feedback on 22.0.398 to verify its now running much faster.
But in general (even in H21) its been noted that the shader-precompile feature can run extra slowly on some machines, exhibiting single-thread-like behavior. I'm curious what types of machines this happens on. Its definitly multi-threaded in code, and runs fast on our Linux machines.
Is it possible for anyone to give specific feedback on this?
eg
- is it slow only on Intel? (in which case it might be an e-cores issue. does disabling the e-cores in the bias make it multi-threaded again?) or is it slow on AMD too?
- is it slow only on Windows? Or does Linux also experience this issue?
thanks lots
eg
thanks lots
- ronald_a
- 299 posts
I‘ve put this in an RFE (because of the locked forum), but I‘ll post this here again:
I am on an amd 64core threadripper, two identical gpus, win11. When starting the caching, multiple (i guess 64) karma_cc.exe start up plus the houdini.exe also has cpu load (total cpu load is near 90%). After about a minute, most of the karma.exe are gone with only 1-3 remaining (cpu load is down to single digits). Not sure if the multithreading should be achieved through having multiple karma.exe running or if the processes running in houdini.exe should be more multithreaded.
This makes me wonder if this also affects the compilation time while in interactive mode (for stuff that has not been compiled yet).
- brians
- 626 posts
- ronald_a
- 299 posts
briansronald_a
This is strange, it should only be starting 1 karma.exe (and does so on my windows machine)
Do you have some KARMA_XPU_... environment variables set by chance?
I do have KARMA_XPU variables set - most notebly KARMA_XPU_THREAD_COMPILE = 1. I disabled all the KARMA_XPU variables for now and now the karma_cc.exes are gone. only one karma.exe remains which runs at a steady 2-4% cpu load.
- 8378 posts
brians
eg
I ran precompile on Windows 11 with the following configuration: Intel Core Ultra 7 265k (8P 12E), Nvidia RTX 5080 with 610.88 driver using Houdini 22.0.401
Total time taken was 4 hours 20 minutes 9 seconds. Average core usage was 20%. Usage was almost entirely P-cores and occasionally spiked to all P cores, but was only using 2~4 most of the time. Compiling completed successfully without error.
I don't think the threading is only the issue, it wouldn't be 100x faster if it were using all threads.
- ronald_a
- 299 posts
I deleted any existing cache for H22 and did a fresh run. It took about 7.5 hours (with cpu usage around 2-3%)! Interestingly enough, before doing that, I continued on an existing cache (which was just 7 or eight steps in). After an initial very long step 9, cpu usage increased to about 11% with a remaining time of about 2 hours about 40 steps in. I have seen this behavior before where the cpu usage is somewhat unpredictable. It‘s really weird.
- brians
- 626 posts
ronald_a
cool
at least the karma_cc.exes are gone
jsmack
I'm starting to suspect some kind of file-locking issue within the nvidia cache.
ronald_a
Good to know
ronald_a
Yes it is weird :/
Hopefully I'll be getting an e/p-cores machine soon so I can debug more closely. Will report back findings here.
thanks all
- Hamilton Meathouse
- 220 posts
Houdini 22.0.368.
Tried compiling, went through every single precompile lap before telling me it failed. Took 1hr 45min.
CPU utilization sat around 40% (low was 30, high was 60)
CPU - AMD Ryzen 9 7950X 16-Core Processor (32 threads)
GPU - Nvidia RTX3080 Ti, Driver 581.29
EDIT: Looks like it worked however?
Utilization was high for cores 0-15, lower for 16-31:
[13:59:08] KarmaXPU: Optix Precompile: 548/548 Lap: 1:43:23.66 Left: 0:00 -------- Error Summary -------- PID: 14492 Command: karma --renderer BRAY_HdKarmaXPU -o husk:null_raster -p1 --res 1 1 C:/PROGRA~1/SIDEEF~1/HOUDIN~2.368/houdini/usd/karma/kma_precompile_shaders.usda -------- 548 total errors -------- [12:15:47] KarmaXPU: Optix Precompile: 1/548 Lap: 0:02.56 Left: 23:19.77 [12:15:49] KarmaXPU: Optix Precompile: 2/548 Lap: 0:03.78 Left: 17:12.72 [12:15:56] KarmaXPU: Optix Precompile: 3/548 Lap: 0:11.25 Left: 34:03.40
Edited by Hamilton Meathouse - Aug. 11, 2026 17:41:54
- jason_iversen
- 13289 posts
Houdini FX Version 22.0.408
Open Source Information: https://www.sidefx.com/docs/houdini/licenses/index.html
Operating System: Microsoft Windows 11 Pro x64
Processor: 11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz
Number of Cores: 16
Physical Memory: 63.71 GB
Number of Screens: 2
Screen 0: 3840 x 2160 at 0,0
Work Area 0: 3840 x 2088 at 0,0
Screen 0 DPI: 163.3
Screen 1: 3840 x 2400 at 3840,0
Work Area 1: 3840 x 2280 at 3840,0
Screen 1 DPI: 283.5
Platform Build: windows-x86_64-cl19.42
Python Version: 3.13
Qt Version: 6.8.3
USD Version: 26.05
USD git URL: https://github.com/sideeffects/USD.git
USD git Revision: ee7b08cf5dae8ff0a206ee907be0326288ab59bf
UI Scale: 1.500
Detected GPU: NVIDIA Consumer
8192 MB
610.47.0.0
Vulkan Vendor: NVIDIA Corporation
Vulkan Device: NVIDIA GeForce RTX 3070 Laptop GPU
Vulkan Version: 1.4.341
Vulkan Loader Version: 1.3.0
Device Heaps: 8018 MB
Jason Iversen, Technology Supervisor & R&D Lead @ WetaFX
- Mirko Jankovic
- 317 posts
ugh.. H22.0.409 Daily build
edit: it did drop down significantly after a while:
KarmaXPU: Optix Precompile: 436/446 Lap: 1:13:41.27 Left: 1:41.41
KarmaXPU: Optix Precompile: 437/446 Lap: 1:13:49.75 Left: 1:31.23
KarmaXPU: Optix Precompile: 438/446 Lap: 1:13:56.18 Left: 1:21.03
Edited by Mirko Jankovic - Aug. 12, 2026 12:17:11
- brians
- 626 posts
- brians
- 626 posts
Hi guys
After much debugging (and a new PC
) we've now fixed this issue. It was a fault in the NVidia CUDA/Optix compiler affecting Blackwell GPUs.
22.0.422 will have the fix. Please give it a try and let us know here if your precompile times are back to normal.
Thanks very much for your patience on this one.
) we've now fixed this issue. It was a fault in the NVidia CUDA/Optix compiler affecting Blackwell GPUs.22.0.422 will have the fix. Please give it a try and let us know here if your precompile times are back to normal.
- jason_iversen
- 13289 posts
- ronald_a
- 299 posts
- brians
- 626 posts
jason_iversen
I'm probably not the target audience with my RTX 3070 Laptop card, but:
At least we have 91% utilization of your CPU now. I'll try to bring the cost down further over the coming days/weeks.
some questions:
- is this a regression for you Jason? Or has it always taken this long? (ie even in H21?)
- whats the temperature like on your CPU while this is running? (something like HWinfo can report this). Is it possible the Laptop is old and the CPU is overheating/throttling?
ronald_a
I'm afraid, this still does not work for me.
What are the symptoms now? Are you able to post a screenshot like what Jason did?
Also, can you confirm you no longer have any KARMA_XPU_... environment variables set?
thanks
Edited by brians - Aug. 26, 2026 00:16:40
- ronald_a
- 299 posts
briansjason_iversen
some questions:
- whats the temperature like on your CPU while this is running? (something like HWinfo can report this). Is it possible the Laptop is old and the CPU is overheating/throttling?ronald_a
thanks
Well the symptoms are just like before - only a fraction of the available CPU cores are used (about 20/64cores (128threads)). Also, the used cores do not seem to be maxed out but work at around 10-50%. I can confirm that no KARMA_XPU variables are used. If I can help by running some debug code here, I am more than happy to do so.
- Mirko Jankovic
- 317 posts
- 8378 posts
It's about the same for me. It got about an hour faster, but still takes an order of magnitude longer than anyone else on here-about two hours. Utilization varies between 40 and 80% now instead of 10-35% though. Scheduling is bad, E-cores are getting maxed out before P-cores. Most E-cores sit idle though with all but 2 P-cores sitting at 45-60% non-idle power state. Total package power usage is only around 60-80 watts, less than a third full power. This CPU uses around 200 while rendering.
- jason_iversen
- 13289 posts
briansYes, sadly, according to this post above [www.sidefx.com], I was getting ~3 hrs predicted before .422. Now it's over 20 hrs...
Ah wait -- I updated my display driver, made sure I wasn't in battery-save mode and now it's back in the slot:
Edited by jason_iversen - Aug. 27, 2026 04:45:54
- brians
- 626 posts
jason_iversen
OMG...
I'm glad its now working again, thanks for testing Jason.
ronald_a
That just leaves ronald_a now.
I think we can try a few things
eg
- do you have some kind of power-save mode enabled on your computer?
- what if you do a KarmaXPU render using only the CPU (ie KARMA_XPU_DEVICES=embree), do all the cores light up then?
- what happens if you update to latest driver as well? (616.56 dropped on Wednesday)
- what happens if you set KARMA_XPU_THREAD_COMPILE=1 again? do you see all cores light up initially as you did originally? (it means it seems to parallelize when we fire up multiple processes, rather than multiple threads).
- what total time do you actually get? Perhaps task-manager is saying low-usage, but in reality its working fine?
