Hi !
I want to create some geometry, that is recursive.
But I am stuck.
something in the lines of
func (x,y,z,size,level,Obj)
for i=0 to 2
for j=0 to 2
for k=0 to 2
if (i!=1) or (j!=1) or (k!=1) then
if level>0 then
func (x+i*size,y+j*size,z+k*size,size/3,level-1,Obj)
else Obj(x+i*size,y+j*size,z+k*size,size)
next k
next j
next i
removeDoublePoints()
removeDoubleEdges()
removeDoubleFaces()
SetPivot()
endfunc
Using Geometry nodes should be inappropriate, because I guess, I am not allowed to feedback a nodes output…
What did I miss… ??
TIA !
[Q]: How to create "recursive" geometry ??
3906 5 1- WhoDjini
- 94 posts
- wolfwood
- 4270 posts
- WhoDjini
- 94 posts
Wolfwood
There is a Feedback SOP in the protoinstall.
THX Wolfwood,
but you're just confuzing me. I'm still confuzed. Only “Feedback” node found so far is a CHOP… (me still noob!!) and the 9.5 online help did not show anything related to protoinstall.
I thought I could use some Hscript/Python, to implement that function.
Thanks for your suggestion anyway!
Edited by - Jan. 5, 2009 15:37:38
If you can't script/program it, it's no good at all !
- edward
- 7768 posts
- jason_iversen
- 12545 posts
Also, look at the ForEach SOP
- malexander
- 5172 posts
but you're just confuzing me. I'm still confuzed. Only “Feednack” node found so far is a CHOP… (me still noob!!) and the 9.5 online help did not show anything related to protoinstall.
You need to run the command line tool, proto_install. Select Windows->Shell from the main menu. Then do:
source $H/houdini_setup
proto_install
SOP_Feedback.inst should be somewhere in the list; enter the number & select “2) Install in …/houdini9.7”. Restart Houdini, and it should appear in the SOP list.
Proto-installed OPs are operators that are not yet tested for full production use, so use them with care.
