Hi
I'm trying to make this fluid smoke, and so far I'm liking it a lot
I can't seem to find how to control the fading of the smoke, something like the life span on particles
There's a sample of my test, if any one has any pointers to make it more real please tell me.
thank you
How to FADE fluid?
7808 6 1- varomix
- 460 posts
- jason_iversen
- 12483 posts
I think what you're asking for is Dissipation - something that the Solver *should* support directly (it's been RFE'd). However, if you're aware of the fluid architecture, it's a one-node addition.
Basically, you scale down your density field incrementally using Gas Calculate DOP.
- varomix
- 460 posts
Thank you Jason that works
Now the issue I have is, I understand this is diffusing from start to finish in a linear fashion, at least it seems like that, could I have even more control of the fade off? , like putting that more at the end? rather than from the start?
maybe like a ramp
thanks again
maybe like a ramp
thanks again
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
- jason_iversen
- 12483 posts
Mmm, you could probably use the Volume Ramp SOP and change the apparent density after the fact?
- varomix
- 460 posts
I'll check out the volume ramp SOP.
although the gas calculate is not bad one my object is moving, looks nice, but having that extra might help for changes
okey, now, what if I want the opposite, I don't want my fluid to ever fade?, like, live for ever. could I just invert the density?, or keep it constant?
thank you again, very nice of you to help me out
- jason_iversen
- 12483 posts
Now, keep it on forever is hard because it'll eventually diffuse out into the entire volume. To keep a crisp smoke stream, hmm, you might find yourself contrasting densities using Gas Calculates.
Or, perhaps you can advect particles through your sim, regarding the particles as “smoke quanta”
- cklosters
- 224 posts
I've been working on a dissipation asset that gives you the option to specify a threshold, weight and falloff curve. It can be easily done using a gas field vop. In my opinion, it might also be better to dissipate based on temperature differences. Instead of the actual smoke volume. Since you want your smoke to behave accurate but fade based on a lower temperature value that get's used to calculate the applied buoyancy force.
I'm just struggling with the fact what dissipation actually is! Something that looses energy over time? IE:
I like the notion of that and it's a good dop challenge
In physics, dissipation embodies the concept of a dynamical system where important mechanical modes, such as waves or oscillations, lose energy over time, typically due to the action of friction or turbulence. The lost energy is converted into heat, raising the temperature of the system. Such systems are called dissipative systems.
Senior Technical Artist Guerrilla Games
