save as doubles the file size
17132 29 2- goldfarb
- 3455 posts
- aplink
- 365 posts
- aplink
- 365 posts
- aplink
- 365 posts
jason_iversen
I have just right now had a bad case of this problem now too. My hip file had hit 623mb before I noticed it - coz it suddenly took 20secs to save.
To repair it, I did the following things in a Shell:
cp myfile.hip /tmp/fixme.hip
cd /tmp
hexpand fixme.hip
cd fixme.hip.dir
cat .application | grep -v imgview2d | grep -v lut | grep -v colorsettings > .appnew
mv .appnew .application
cd ..
hcollapse fixme.hip.dir
.. and you should now have a new fixme.hip which is small and works ok.
This stripped out all the imgview, lut, colorsettings lines from the .application settings file, so you might have to set these right again.
Thanks,
Jason.
Can you help me further how to fix the same problem i have .
I am a beginner in houdini.
steve
- stevenong
- 1631 posts
- aplink
- 365 posts
stevenong
The most straightforward way, if you don't have a complicated scene, is to start a new Houdini session with the latest build you downloaded and also open your current hip file. Now, you can copy & paste from your current file to the new session and save it. Done.
Cheers!
steven
Thank you very much
I havea huge problems with huge snow-balled file size, even 2 gb +.
I have an animated body. I will try. Thanks
Steve
- aplink
- 365 posts
stevenong
Cheers!
steven
THANK YOU VERY MUCH !
1.8 gb shrunk to 1000kb.
Did a hacker placed this bug in my computer and took my files already ?
I'd like to know if that is the case. Thanks million !
Steve
- Allegro
- 696 posts
- aplink
- 365 posts
- Allegro
- 696 posts
