I have a very strange behaviour with my current hipnc file. I found out that for some reason houdini doubles the file size if I save my work file. So my workfile is now 16 MB in size and when i save it again or save it with another name i get a file size of 32MB.
Hmmmmm
save as doubles the file size
17063 29 2- roughsporty
- 191 posts
- JColdrick
- 4140 posts
- roughsporty
- 191 posts
- JColdrick
- 4140 posts
- roughsporty
- 191 posts
- edward
- 7715 posts
- buki
- 1769 posts
I think You have found the bug which i reported already:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16066 [sidefx.com]
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- goldfarb
- 3455 posts
- roughsporty
- 191 posts
buki
Yes, I have the same “\\\”. The whole file is full of it.
- edward
- 7715 posts
buki
How is that “me”? Does anyone know if it was actually submitted? I'd assume that it wasn't submitted unless someone said so and gave you a bug id.
- edward
- 7715 posts
- Ondrej
- 1072 posts
- jason_iversen
- 12461 posts
I have just right now had a bad case of this problem now too. My hip file had hit 623mb before I noticed it - coz it suddenly took 20secs to save.
To repair it, I did the following things in a Shell:
cp myfile.hip /tmp/fixme.hip
cd /tmp
hexpand fixme.hip
cd fixme.hip.dir
cat .application | grep -v imgview2d | grep -v lut | grep -v colorsettings > .appnew
mv .appnew .application
cd ..
hcollapse fixme.hip.dir
.. and you should now have a new fixme.hip which is small and works ok.
This stripped out all the imgview, lut, colorsettings lines from the .application settings file, so you might have to set these right again.
Thanks,
Jason.
cd /tmp
hexpand fixme.hip
cd fixme.hip.dir
cd ..
Thanks,
Jason.
- malexander
- 5158 posts
- buki
- 1769 posts
I submitted the bug, and it is now fixed in 10.0.314, thanks SESI!!
- aplink
- 365 posts
JColdrick
You can lock SOPs, the button on the middle left of the node. That will lock the data into your hip file, making it get larger. Not sure that's the reason, just the first thing that occurred to me.
J.C.
I have the same problem, doubling the file size.
How can i know nodes are locked. i am not quite sure about the button on the middle left of the node
Steve
- JColdrick
- 4140 posts
- aplink
- 365 posts
JColdrick
As mentioned above, there was a bug fix, grab the latest release. The issue of locking data was just a suggestion that was likely unrelated. How to lock data in SOPs is dicussed in the intro to Houdini interface in the help, I believe…
J.C.
I downloaded the latest version and copy , paste the code in the shell that the above Jason explained. I believe i also manaually deleted the junk ///////// . But i still have the huge size, 2.3 gb. or a little reduced to 1.5 gb. How can i submitt the bug ?
Can you help me further how to reduce and fix all the huge files saved in my hard drive. Thanks very much.
Stev
- goldfarb
- 3455 posts
- aplink
- 365 posts
