Is there any way to output custom image planes with Physically Based Rendering in Houdini 10?
The way I set it up in Micropolygon doesn't seem to work in PRB.
Custom Image Planes with PBR
13230 14 2- xtimmyx
- 166 posts
- mrbag
- 21 posts
- xtimmyx
- 166 posts
Well, I'm talking about custom frame buffers in the shader. To be able to output things like specular, occlusion, masks and stuff directly from the shader just like I can in the Micropolygon renderer.
But I haven't found any way to export BSDF's from a shader just like I can export any vector to an image plane. And just trying to export a vector as usual gives a blank image.
- brianBurke
- 192 posts
Hey ya'll. Unfortunately, because of the nature of the PBR engine some of the things you're talking about (specular highlights, occlusion, etc) don't exist in pbr.
This doc pretty much has all the info you want. http://www.sidefx.com/docs/houdini10.0/rendering/understanding [sidefx.com]
If you just want to set up variable exports unrelated to lighting like id masks and flat passes and such, you can enable this in PBR by setting up the exports in the usual way and enabling the “generate surface shader exports” rendering parameter.
Good luck dude.
Good luck dude.
- xtimmyx
- 166 posts
brianBurke
Perfect! Just what I needed. Thank you very much.
- jason_iversen
- 12503 posts
brianBurke
Actually, these components do exist in PBR. And they've also seemed to have undergone a name swap - but they haven't really; they're just named accurately for what they now really represent.
- “diffuse” remains “diffuse” in PBR
- “specular highlight” becomes the “glossy” component in PBR (ie, the soft reflection caused by substrate/etc)
- “reflections” becomes the “specular” component in PBR. (ie. sharp reflections)
These components can be output into deep raster layers too! There are a bunch of special names you can export now, (although I don't think I see documentation for them in the 10.0 docs). These are all vectors, and come in direct and indirect flavours:
- direct_diffuse, indirect_diffuse (viz. diffuse reflection - those color-bleeding effects)
- direct_specular, indirect_specular (viz. caustics)
- direct_glossy, indirect_glossy
Edited by - Sept. 28, 2009 12:43:04
- xtimmyx
- 166 posts
- JColdrick
- 4140 posts
- xtimmyx
- 166 posts
JColdrick
If I follow you, you don't need them. The alpha is there, you don't need another one, the existing one will work fine.
I should point out that AFAIK the PBR exports don't currently have a mechanism to deal with shadows.
J.C.
That works in some cases. However, when an object with transparency ends up in front of another the alpha is solid anyway, but the object in front is covering what's behind it.
- brianBurke
- 192 posts
jason_iversen
I totally agree. It is worth mentioning tho that some things the original poster might be looking for aren't there. Direct and indirect occlusion (shadow) doesn't exist seeing as there is no difference from a light path and a shadow path. Specular highlights also don't exist because, as you mentioned, these highlights are computed as glossy reflections.
- tjzfx
- 5 posts
- xtimmyx
- 166 posts
tjzfx
So there is no export for shadows in PBR. I have a nice PBR setup with an environment light. The only thing I need are ground shadows, so I can comp my objects over a background plate. Is there a way to get a shadow pass which is simliar to my environment light PBR setup, with another render?
You could set up another take for rendering shadows and rendering that with an other mantra connected to your primary mantra.
Create a new take and check phantom on the objects you want to cast shadows, and assign a shadow matte shader to the ground. You'll need to make overrides for the phantom and material on the ground plane.
However there´s probably/hopefully a better way to separate shadows in the shader. I've found a “hidden” node that converts a vector to BSDF in the shader so that any vector output can be rendered in PBR.
However I've noticed that using the export custom planes in PBR slows down the rendering time significantly compared to what it does in micropolygon.
- tjzfx
- 5 posts
xtimmyxSince I only have one environment light in my scene with IBL in PBR, what should my new Mantra type be?
xtimmyx
Care to share this “hidden” tip? 8) So the vector I want would come from the shadowmatte shader, which is derived indirect/direct occlusion.
brianBurkeSo said vector, with this vec to BDSF export, coming from the shadowmatte would be a combo of the light/shadow from PBR, hence expensive rendertime… am I getting this right?
In my case, render time is not a problem, it's for a still, and it's more proof of concept… one light, minimal passes, accurate results.
- xtimmyx
- 166 posts
- xtimmyx
- 166 posts
