Shaking to disconnect a node doesn't seem to work anymore, is this broken in 21.0.440 ?
Or is there some preference that needs to be set ?
edit : only when using the Wacom, with the mouse it still works, is this known and is there a fix ?
shake to disconnect
1245 3 4-
- toonafish
- 572 posts
- Mike_A
- 396 posts
I have my 'Shake distance' set low (0.25) in Prefs (Network Editor, Nodes...). I'm normally using mouse - as you say it works as expected. I did get it to work with my Wacom - but I had to shake very violently - much harder than with the mouse, so maybe a bug as you suspect. Decimal point in the wrong place? : )
Edited by Mike_A - Aug. 31, 2025 07:38:15
- toonafish
- 572 posts
- chrism
- 2619 posts
