Drive Light position by Point position? {[SOLVED]}
   563   3   0
Hi!
Inside a Geo Node, I have one point with a f@myFloat. I'm trying to access that float from a Light(translate X) by using a point function. I get the error Unable to evaluat expression (bracing error(./tx))).
Can anybody help me?
-Olivier
Edited by olivierth - June 6, 2026 15:18:07
-Olivier
on top of mismatched brackets, you are also not using the correct form of point() function, since hscript [www.sidefx.com] and vex [www.sidefx.com] versions expect different arguments
try this one
point("../geo1/OUT/", 0, "myFloat", 0)
Edited by tamte - June 6, 2026 14:18:02
you can also use RMB/Reference/Scene Data... to link any parameter to an attribute without typing the expressions manually, especially handy for something like position where you have to link 3 parameters
Edited by tamte - June 6, 2026 14:41:32
Thanks for the info!
-Olivier
-Olivier
