trying to follow along with some tutorials….
i can type help for command example
exhelp prim
and it will display the help for the command
but when i type it in it is coded red and says
unknown command prim
when i start typing “prim” the popup for commands starting with “P” appears but prim or prims is not on the list
I tried this with other commands that are on the list such as “parmlist”
and when i type
exhelp parmlist
it returns
No installed expressions match parmlist
to me it seems it isn't finding installed expressions….is it possible that it is referencing an improper file location for expressions?
problems in scripting textport
4496 6 0- m.d.
- 34 posts
- probbins
- 1145 posts
- m.d.
- 34 posts
i'm not actually trying to use parmlist I was just experimenting
what i am trying to do is use prim….
which i have searched out in the help and found an expression “prims”
let me paste what i typed
/obj/soccerball -> prim(“./measureArea”, 8, “area”, 0)
Unknown command: prim
/obj/soccerball -> exhelp prim
float prim (string, float, string, float)
usage
prim(<<SOP>>, <<prim_num>>, <<attrib_name>>, <<attrib_index>>)
This function can be used to get information about a specified
primitive. When given the “P” or “Pw” attribute, the centroid of the
primitive will be returned.
examples
prim(“/obj/geo1/facet1”, 3, “P”, 0)
Evaluates the X component of the centroid of primitive 3 in the
sop specified.
prim(“/obj/geo1/facet1”, 3, “Cd”, 1)
Evaluate the green color of the “Cd” attribute of primitive 3.
SEE ALSO: primuv, point
the unknown command thing is throwing me
usage
examples
sop specified.
- m.d.
- 34 posts
- edward
- 7724 posts
That's because prim() is an *expression*, not a *command*. It also explains why it's only available when using “exhelp” and not “help”.
http://odforce.net/wiki/index.php/Expression [odforce.net]
- m.d.
- 34 posts
what is the correct context to use this in then….
i'm following along with magic of houdini, which of course is H8
i've entered this expression in the textport and Hscript textport both with the same results….but in the book that's what he directs you to do to test the expression
in the book he has you preceed the expression by the echo command
which i do
/obj/soccerball -> echo ‘prim(“./measureArea”, 8, “area”, 0)’
and houdini returns
/obj/soccerball ->
but in the book the echo command returns the attribute number itself
when i do it it dosn't seem to evaluate the expression
which i do
and houdini returns
/obj/soccerball ->
- m.d.
- 34 posts
