Greetings!
I'm curently using polysplit for all my polysplitting needs: tracing splits on a object OR by changing the tool options to be able to do Edge loop split*. The tool works well, but it gets a little tidious when you need to change the options by hand everytime I want a edge loop split*. I like to be able to have a node for each operation to make to process faster.
I'm pretty sure there's something I can do using the shelf to duplicate the polysplit tool with the edge loop split* options on..but how?
Thanks in advance!
***When I talk about options for performing a Edge loop split using Polysplit, I'm talking about changing “path type” to “QuadStrip” and checking the “Closepath” box in Polysplit parameters…just to make things clear.
Sop: Separated Edge Loop Split tool from Polysplit
6244 4 0- jrgauthier
- 243 posts
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
www.turboatomic.com
- circusmonkey
- 2624 posts
- jrgauthier
- 243 posts
Thanks for the awnser!
The way I understand it, and I tested it, is that I can actually add a preset to the tool.
But idealy I'd like to have a separated tool to do the Edge loop split, so I would not even have to bother to go and activate a preset everytime.
I know I can make the edge loop option as default, but then I have the same problem to acces the normal polysplit.
So I was wondering if there is a way to do it using the shelf. The best exemple for what I want to do is in the shelf “deform” tab; the twist, bend and taper tool which are actually the same tool but with different parameters setting, that exactly what I'm looking for.
I actually tryed to drag a Polysplit sop with the right setting in shelf. seem to work at first but, when I try to use it…well it creates the icon but something seems to be broken it doesn't work properly….
Maybe there is actually a way to do this with what you explained Circusmonkey, but I'd would need more details to understand… :roll:
thanks!
thanks!
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- circusmonkey
- 2624 posts
Create yourself another Houdini Digital Asset from the polysplit tool with your own settings.
As to the shelf , there is a open office document on this and tool building
building tools here
http://www.sidefx.com/index.php?option=com_content&task=view&id=966&Itemid=132 [sidefx.com]
The power of houdini's shelf here
http://www.sidefx.com/index.php?option=com_content&task=view&id=868&Itemid=264 [sidefx.com]
A fx tool shelf to install here
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=274 [sidefx.com]
Rob
building tools here
Rob
Gone fishing
- jrgauthier
- 243 posts
Thanks alot Rob!
Ill have a look at all of this!
JR Gauthier
www.turboatomic.com
www.turboatomic.com
