RFE: Delayed Load Procedural to support velocity blur
   10439   7   1
It will be great if the Delayed Load Procedural supports velocity blur. I understand currently the procedural performs a lerp on the geometry file so for velocity blur, a simple multiplication will be good.
Pretty please…
Cheers!
steven
Yep I would like to see this too. And segmented deformation blur
f = conserve . diffuse . advect . add
fx td @ the mill
yep doit.
o it would be a great day if this was implemented!
jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
Yes please do this! Got bitten by this on our last project.
Sean Lewkiw
Machine FX - Cinesite MTL
it would be also cool if it can blend geo sequences between frames if it has constant point count
it'll make retiming crowd caches a lot of easier and can be used for deformation mblur maybe
I have been working on this kind of problem for my own instancer. (similar to copying delayed loads onto a template pointcloud).
The way I understand it, it would be something like:
((pscale of template point) * (geometry velocity->pointattribute v on cached mesh)) + (velocity of template point)
The tricky bit so far is that you have to expand your bounds by the maximum v of the cached mesh, otherwise it goes out of bounds.
No clue about how the segmented motion blur works though.
add another name onto the list of people supporting this rfe
Stephen Tucker
VFXTD
