I posted some files on my blog if somebody is interested how to do a stretchy spine.
Any feedback is welcomed
cheers
calin
stretchy spine on vanillarigging.blogspot.com
8328 8 1- calin
- 114 posts
- jrgauthier
- 243 posts
Sweet, really interesting…I'll have a look!
I really wish there would be more material on rigging for Houdini…
Without ausin autorig that is…
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
www.turboatomic.com
- calin
- 114 posts
- jrgauthier
- 243 posts
hi Calin!
I took a quick look at the strechy spine and the strechy spine houdini way.
It seems like a really nice setup, but I don't understand exactly how you could skin a character using cubes instead of bones(in the houdini way).
Once this is done, what are the steps to skin it, do you have to make bones follow the cubes or something like that?
this is really interesting, thanks alot!
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- rmagee
- 1182 posts
jrgauthier
To understand you just have to look at the autorig tools that Calin developed while at Sidefx. You will notice that there are two rigs - an animation rig and a deform rig. The deform rig looks at either bone locations or nulls in the animation rig to get their positions and orientation. These are then used to create either nulls with muscles attached for capturing or actual bones. This two rig approach gives you a lot of options.
- calin
- 114 posts
You could do as Rob suggested or if you are a fan of all in one kind of a rig you could copy metaballs instead of cubes and used the meta capture sop to do the deformation. The possibilities are endless, you could copy nulls onto each point then use the muscle object. That way you could tweak the shape of the body off spine sort of speak.
cheers
calin
ps. I'll show the capturing process, “the Houdini way”, after I'm done with all the rigging bits.
cheers
calin
- jrgauthier
- 243 posts
Is there any twist option for the spine?
Right now when I move back and forth the spineCtrl2, the spine does a weird twist…Is it possible have a twist control per controller and one global for the move back?
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- jrgauthier
- 243 posts
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- amazingjay
- 56 posts
Does anyone know where I can get the sample files from the blog (http://vanillarigging.blogspot.com/2008_03_01_archive.html [vanillarigging.blogspot.com] )? The linked files seem to be dead (e.g., empty)
sorry to bump this thread…
