Ok this is driving me nuts. The display flags are turned on sometimes the objects display on the screen when I open the file. At other times they do not. I can turn off the display flag on an object and it will not disappear. I can turn one on an object and it will not appear. I can then go down into sops where sometimes my object appears and sometimes it does not. But everytime it does appear and I go back to Object level all the objects have disappeared. I can delete objects that are heavy and save it out as a new file and still with very light geometry the objects will not display. Uninstalled Houdini and then reinstalled it on Windows 2000. This did not fix the problem. I turned my resolution down to 800x600, then to 640x480. Still would not work. Then I tried turning down the bit depth to 16 and that did not work either. Why is this happening?
Nate Nesler :evil: :twisted: :x :cry:
All My Objects will Not Display!!!
6449 4 0-
- MatrixNAN
- 405 posts
- MatrixNAN
- 405 posts
- edward
- 8155 posts
- MatrixNAN
- 405 posts
It was set to Never dang it. I must have watched the videos and read the pdfs about that feature a good 100 times yet it just never came to the surface of my thoughts. I was stuck on that for a day and a half. Thank you soooooo much. I feel like such an idiot for not remembering it. Well that made my day. I was really worried.
Nate Nesler
:shock:
8) :idea:
Nate Nesler
:shock:
8) :idea:
- JColdrick
- 4140 posts
Don't feel so bad. There's a school of thought out there that the frickin' “Never” button should be screaming, flashing red and is *never* saved. It can be really frustrating. Damned useful when you're doing something that might inadvertantly make 300googleplex particles
, but typically you want it off by default.
J.C.
, but typically you want it off by default.Cheers,
J.C.
John Coldrick
