Invisible and Reflective; Shadow
8136 10 0- heydabop
- 203 posts
I'm trying to get something to be invisible, but I want objects to be reflected in it. I can do this using opacity on the material pallet, however, this causes the objects reflection to have an alpha value of 0. I would like the reflection to at least have an alpha value of 0.5, is this possible?
Edited by - Oct. 7, 2008 10:45:46
- edward
- 7733 posts
- heydabop
- 203 posts
- heydabop
- 203 posts
Here's an example of what I want.
There's a grid below the Möbius Strip, and it's has an opacity of 0. But this causes the reflection to also have an opacity of 0. I want the reflection to be translucent, with an opacity of something around 0.5.
So you could see the reflection, I had to remove the alpha channel when saving the image. But what it normally has is everything but the strip itself with an opacity of 0.
- probbins
- 1145 posts
- boomtown
- 17 posts
- Allegro
- 696 posts
- heydabop
- 203 posts
- heydabop
- 203 posts
- tamte
- 8594 posts
- heydabop
- 203 posts
