render points
   3785   5   0
Hi all,
I'm looking for the fastest possible rendering of points. I thought about using width attribute but looks to me it only works on curves. Should I use some kind of override on materials?
Thanks for any help.
kuba
kuba
Hi all,
kuba
The width attribute works on points too.
Mark, just discovered that it's necessary to specify local variable for with attribute as well. Previously it didn't work since I only put width in a name field - not very clever of me. :?
Thanks again.
kuba
I definitely miss something…. I attach the file. Line renders fine, points don't…
width.hip (96.6 KB)
don't forget to check Render As Points in Render/Geometry tab of your geo
FX Supervisor
Method Studios, NY
Thanks, that was it. I found out as well that the colour needs to be assigned after creation width attribute otherwise it will be applied only at the edge. That makes sense.
