Can anyone point me in the right direction. I'm trying to get some luminance passes up and running with VOPs. For some reason I'm getting different results when I have 1 light enabled vs. both lights enabled.
When only 1 light is enabled my deep pass looks fine, however, when both are enabled there seems to be a harsh cut-off in the shading contribution to that area.
Any ideas?
(hip attached, hit render and look at deep layers in mplay)
trying to get out light passes in VOPs
4775 6 1- andrewlowell
- 537 posts
- rdg
- 401 posts
maybe this example helps to track down the issue:
http://forums.odforce.net/index.php?showtopic=6969&hl=export+light [forums.odforce.net]
this is not a science fair.
- andrewlowell
- 537 posts
That's cool .. but a little more elaborate than what I was looking for. I guess my question is a little more basic than that.
so, question is .. why does the number of lights active change the result of a single light export in an illuminance loop?
Here I'm simply feeding in the lighting model, and exporting that as the variable. What am I missing?
- wolfwood
- 4261 posts
- andrewlowell
- 537 posts
- wolfwood
- 4261 posts
The variable you export to needs to be set inside the illuminance loop which is why in Peter's example you have a fairly complex VOP network.
Instead of using the Lighting Model VOP you'll need to put together the illuminance model yourself. (Which is what Peter did.)
- andrewlowell
- 537 posts
