RealFlow plugins for Windows version of 9.5 are available only for 32 bit VC7 version. The problem is that ‘realworld’ RF meshes have 1 million or more triangles. Houdini VC7 cannot seem to handle this much data. Though this is not a problem for Widows Maya. I get Memor Allocation Error, whenever 9.5 VC7 memory usage goes above 2.5gb. I have 64 bit Windows.
Does anyone have a workaround for this issue.
Dave Rindner
Problems with Windows VC7 9.5 and RealFow plugins
2597 2 0- Dave_ah
- 436 posts
- edward
- 7735 posts
- Dave_ah
- 436 posts
In RealFlow, mesh object info states how many polys are in a generated mesh.
In Houdini , as you know, simple middle click on a node will tell you triangle count and memory usage.
But here is one workaround.
In VC 7 32bit version, set SOP culling to 5 and OBJ cache to zero, in Preferences.
Convert RF bin files to BGEO sequences using GeoROP. Then transfer to 64 bit version for further work.
DaveR
DaveR
