I installed and authorised 3Delight 6.5
However when I try to render with it using 9.5 I get RenderDL crash.
RenderDL is 3Delight's rendering bin like PRMAN's prman.exe.
I don't understand why the crash happens.
The Rendram ROP is set to 3Delight and render command is set to renderdl.
Anyone else having issues with 3Delight and H 9.5 under 64 bit Windows
Help with Vista64 Houdini9.5 and 3Delight
12439 17 1-
- Dave_ah
- 436 posts
- Pagefan
- 519 posts
- Dave_ah
- 436 posts
Well I hit on a quandry. Where information from DNA (in their docs) and Houdini features are mismatched.
According to DNA the RendermanROP needs to be set 3Delight v7. Houdini 9.5 suppourts as far as 6.5. I think that is the cause of the crash.
What I don't get is why would DNA docs state to set ROP to a setting it does not have? Weird.
On Mays side 3Delight works great.
- wolfwood
- 4344 posts
I'd ignore 3Delight's docs. If you installed 3Delight 6.5, then setting the target to 6.5 seems logical.
Programs shouldn't crash, so if you have a 3delight file which was generated by Houdini that is causing 3delight to crash then you need to take that up with DNA's support team.
- Dave_ah
- 436 posts
- Pagefan
- 519 posts
David, i did a test render and seems 3delight8 just works from houdini using the 3delight6.5 option. I am not using windows though, linux here…You might try to set the option HOUDINI_DEFAULT_RIB_RENDERER=3Delight6.5
Hope this get's it working for you.
edit:removed the quotes on 3delight6.5
Edited by - Jan. 10, 2009 16:14:45
- varomix
- 460 posts
HI
Yes 3delight 8 works fine in houdini just like Pagefan said
add the environment variable
HOUDINI_DEFAULT_RIB_RENDERER=3Delight6.5 (no quotes)
you can check out your 3delight installation by opening the command prompt and typing renderdl -test if that shows you a nice render, then is working
if not post the results to see if I can help you
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
- Dave_ah
- 436 posts
- Dave_ah
- 436 posts
I don't know what to do!
renderdl -test works fine. The space invader comes up.
Does not work at all in houdini.
My render commnad is set to renderdl
Properties display is set to i-display. But that setting is irrelelevant
Display Device is set to tiff
Display channels is set to rgba
The result is the same. renderdl crashes when houdini tires to render.
Simple scene.
One camera , one light, and a sphere.
I can't test render through i-display, I can't test render in GUI, and I cannot do a normal render from a ROP. From my POV 3Delight functionality in Houdini is DEAD!
DaveR
Simple scene.
DaveR
- Alanw
- 320 posts
you responded, making my post irrelevant~
That is good that renderdl -test is working.
Can you export a RIB file from Houdini and render it from the command prompt?
Or can you render any non-houdini generated RIB from the command line?
Also, I would imagine you went through all of this?
http://odforce.net/wiki/index.php/3DelightSetup [odforce.net]
it's for a linux environment, but still should apply for the most part.
Edited by - Jan. 11, 2009 15:10:24
- Dave_ah
- 436 posts
- Pagefan
- 519 posts
- Dave_ah
- 436 posts
- varomix
- 460 posts
- katisss
- 14 posts
- Bernard
- 523 posts
- wlaroussi
- 39 posts
Hi ,
I had the same problems as Bernard . I just can tweak some paramaters like filters or pixel sampling . No way to to see shaders or textures in shader view . The slo/sli files must first be translated to dso or something else i guess before succeding in that way , and in that last part i failed . so I'm just using Mantra and it's doing must of the jobs . Renderman and 3delight are Prman compliant renderers like Mantra . How ever it's would nice if i can use mantel ray standalone with houdini master , but even at this step i failed . I decided to not waist my time doing things like in Maya or other packages .
Regards .
Regards .
- patar
- 280 posts
