Hey everyone,
I am sorry to forget posting to the forum again. we will be creating a press release page to make things easier in the future. . but here is the video we promised to the Maya migrators
cmiVFX Launches New Video: Houdini Introduction To Particle Animation
Watch High Definition Training Videos For The Visual Effects Industry Instantly From Anywhere In The World.
Princeton, NJ., February 15, 2009 — cmiVFX | cmiStudios launches yet another Houdini Software Training Video for its customer base. Particle animation training has always been limited by selection. cmiVFX is proud to offer the most robust particle training for a large majority of animation packages. The Introduction To Particle Animation Video is geared towards training entry level individuals or those migrating from other animation packages. All prospective Houdini artists should make this a requirement for their training library. (Video is about 4 hours in length)
This video is available today at the cmiVFX store. http://cmivfx.com/store/Browse.aspx?Category=11 [cmivfx.com]
Product Announcements — Houdini Fluid FX For TD's
http://www.cmivfx.com/SideFX_Houdini_Training/houdini_introduction_to_particle_animation/default.aspx [cmivfx.com]
Creating Particles
Everything has a beginning, and a particle network in houdini always begins with the creation of the particles. You will learn in this chapter the first steps for creating particles. we will be using a location emitter to demonstrate how and where to create those particles.
Location Node Parameters
In order to manipulate particles, the first parameters to change are in the the location node. Since it always begins with the creation, learning the parameters in this phase is a crucial achievement towards getting the most out of your project. During the explanation of the Location Node Parameters we also show the details view, an important place to visualize many of our particles parameters.
Emitting Particles From Geometry
Users are not limited to emitting particles from a location. You can also use custom geometry to emit particles from. Continuing in the particles creation phase, we will be discussing how to use geometry to emit particles using the source node. We will talk about its parameters and we will see how it can inherit velocity from the source geometry. Then we will end up creating a very simple basic rain example.
POP Network Parameters
Particle placement can't really exist without a simulation. In the POP Network Node, we can control some of the simulation parameters. In this chapter of the video, you will learn about the parameters of the POP Network, which will prove very useful in several situations.
Initial State
Sometimes users may just need particles to begin from a certain point in time, after the begining of the simulation. One simple and efficient way of achieving this is by using Initial State. In this section of the video, we will show how to create and import an initial state file, applying that to an example in which we will blow up a fruit bat into a number of smaller fruit bats.
Gravity And Force Attributes
Forces and dynamics are mandatory in order to drive simulations because they reproduce real life situations in a fast and easy way. Here we will begin with the gravity node and explain the basic force parameters. We will also show the property node, a very useful node that we will be using often later.
Fan-Wind-Noise
Fan and wind are two important force nodes that can help you achieve many cool effects. Randomizing things with noise creates a more organic style of movement then with velocity or force used alone. This part will explain in detail those 3 nodes and how to use them in order to continue the bat example. (ending it by blowing up the bat to small bats.)
Planetary Systems
Beside smoke, fire and other widely used visual effects, particles can serve to a different type of effect simulation. We combine and explain a bunch of nodes such as the orbit, torque, group, drag and more in order to create a not so common effect with particles: a planetary system.
Commercial Soda Bubbles Effect
This chapter is all about making the bubbles in a glass of soda with complete detail. We will make them appear on the inner surfaces of the glass, change size with age, and float to the surface where they will burst when colliding with the liquid surface. We then talk about the collision node which is used for the collision of the bubbles with the surface. Continuing, will also show how we can make our particles interact with rigid bodies and collide with them without using the collision node.
Shading And Rendering
What's life without color? Just an old black and white tv with bad reception. In this section, we will be using some of what we have learned in the previous sections to make an electric saw cut into a cube. Then we will learn how to give colors and alpha to the sparks emitting from the saw and change them with time. We show how we can use the render pop to change some of our particles attributes such as shape, and we will end up giving our particles some motion blur.
Sprites And Rendering
Sprites are a very important aspect of particle networks. They are fast, efficient, and allow you to create very interesting effects such as smoke, dust and more. This part will be dedicated to sprites, showing how to create them, color them, control alpha, and how you can attach textures or custom shaders to them all while setting them up for Mantra to render.
About The Author
Georges Nakhle is 25 years old, lebanese, and has a masters degree in mechanical engineering. he has a wide artistic and scientific knowledge, he began his art steps with traditional painting and sculpting then gained a diploma in dramatic monologue (acting -singing), he has worked as a writer and perfomer in radio and TV. combining arts and science led him to CG, so he mastered many 3D tools such as Maya and houdini, he's also a programmer so he's currently working for dassault systemes in Paris-France and he had also worked in combination between Dassault-Systemes and mental images the makers of mental-ray. He is very picky about the details and he believes that every small detail contributes to the finished product.
About cmiVFX
cmiVFX is the leader in High Definition Video Training for the Visual Effects Community. To test drive the new cmiVFX TVOD © system, visit http://www.cmivfx.com/cmi_window.html [cmivfx.com] For additional information about cmiVFX, visit www.cmivfx.com.
© 2009 cmiVFX | cmiStudios. All rights reserved.
8657 5 1- wavesmack
- 132 posts
- wavesmack
- 132 posts
You can write me at chrisATcmivfx.com
I will be more then happy to discuss with you all of the options that are available.
-c
-c
- circusmonkey
- 2624 posts
- zauberberg
- 24 posts
circusmonkey
Theres plenty of really cool examples that ship with houdini .All you need to do is hit the help for each node !.
R
Thanks for the hint and I'm already using the help files frequently - but not all of the files are local - for some Houdini tries to connect with the I.net . and as mentioned above –> I don't have one … Hope that Houdini 10 provides all the help files for local use.
mfg
- whalerider
- 194 posts
- edward
- 7733 posts
primzahl
I think the only reason why is does that is because there's comments that users can type into the help pages directly that get saved onto a centralized server. So when you go view a help page, it might try to access the internet to retrieve any available user notes. If you don't have an internet connection, your help should work fine. You just won't see the extra notes that various users have added themselves.
