Hi! I'm learning coding in Houdini, but I'm getting problem with copletion.
This is when I'm writing an expression f.e. at a scale field and I write:
stamp(" - code copletion shows, but when I make an error in my code and want to write it again, code copmletion doesn't shows. Is there any way to show it back?
Thank you
code completion problem
3336 1 1- danilo2
- 277 posts
- Tranguz
- 22 posts
This is an unusual behaviour. I really don't have any problem with code completion as I type back and forth. I can get a suggestion list of all functions that start with characters i'm typing and a reference of the function required parameters as well. You can get code completion even moving the cursor inside the expression.
Check your “scripting” settings under program “Preferences”
