I want to to bring in the life of each particle into a shader vop and use this
value to manipulate the alpha of each point.
I understood that the equivalent of $LIFE is attribute 'life' divided by 'life'.
But how can I bring in this attribute?
Do I have to use the ‘get attribute’ - vop?
The help seems to be buggy here, because when I click the question mark sign,
the help throws an error.
Any help appreciated
Cheers
How to import particles' life into a SHOP-VOP?
5136 5 2- botti
- 38 posts
- old_school
- 2540 posts
- botti
- 38 posts
Thanks, Jeff.
I begin to understand (slowly though) the concepts behind VOPs… )
I figured it out. In a VOP SOP I can chain together
‘Global variables (life)’ -> ‘Ramp Parameter (spline/float)’ -> ‘Add attribute (Alpha)’
I thought, everything works fine now, but I'm running into a new problem
I set the highest value of the ramp to 1, but the resulting values for the alpha are all above 1.
In the spreadsheet I can see that ‘life’ is something between 0.0 and 1.0;
the resulting alpha values are between 1.0 and 1.1 .
Cheers ?
Cheers ?
- botti
- 38 posts
- edward
- 7743 posts
It's possible to interpolate higher than 1.0 values in the ramp editor. It's also possible to set ramp points with values higher than 1.0 as well … it just can't show you higher values. Double-check all your ramp key values are less than or equal to 1.0 and try changing the interpolation function to something that can't overshoot (ie. anything other than catmull rom).
- botti
- 38 posts
