Hi Everybody,
Is there a way to see fractionnal keyframes in Houdini ? I have something rotating very quickly, 360 ° in one frame, I'm looking for a way to see it's movement between , let's say for example , frame 1 and 2 . Like if I was sliding time between frame 1 and 2 .
Thanks in advance
Julien
Fractionnal Keyframes ?
4097 4 1- Undertaker
- 113 posts
- davedjohnson
- 221 posts
If you click on the little tiny square at the far right side of your playbar, then your frame range will show. There is a parameter dialog box for that area (it looks like a + sign). If you click on that, you'll get a dialog box. In the lower part of that box is a switch for “Integer Frame Values”. Uncheck that box and you can slide between frame 1 and 2.
Dave
Dave
- Undertaker
- 113 posts
- JColdrick
- 4140 posts
- Undertaker
- 113 posts
