I was watching recently oneof the H10 tutorials and I saw that in this tutorial the man had 2 curves -> merged -> attached to rail sop -> …
And after he pressed the first curve and added the edit sop he could select points and move them around withoud the need of changing the tool (he used the move tool).
So I simply cannot select these points - to select onother point I have to press “`” (or “s”) then select new point and then change back to move tool.
How can I select points without changing the move tool to select tool?
Thank you very much
fast selection change
1919 2 1- danilo2
- 277 posts
- edward
- 7721 posts
Are you single-clicking on the point and then letting go of the mouse button right away? If I do that, then the handle appears with the new point selected.
If that doesn't work, then from the top main menu, go to Edit > Preferences > Objects and Geometry. Now make sure you have the following settings:
- Use Existing Selection to Complete Action ON
- Secure selection by default OFF
If you made any changes, then make sure to click OK and then restart Houdini.
- danilo2
- 277 posts
I'm sorry.
I don't understeand, why, when I was trying it before it didn't work.
I tried a lot of times, restrting houdini too.
These settings were good and this didn't worked - probably i have had made a mistake before, but now
when I launched Houdini everything working as it should.
So thank you veryvery much and I'm sorry that I took yours time
