Hi!!
I have try to convert my *.slo shaders with slo2otl.py, but always the shell say´s:
line 12, in <module>
import rmands
ImportError: No module named rmands
Thanks.
slo2otl.py Error
4364 4 0- Alejandro Echeverry
- 691 posts
- mark
- 2595 posts
alejandro
Hi!!
import rmands
Thanks.
Try running “hython slo2otl.py *.slo” instead. The rmands module is part of the Houdini distribution, so Python needs to have the proper path set up. hython should do this.
- 691 posts
Hi!!
It didn't work, the shell says:
hython can´t open file ´slo2otl.py´: No such file or directory
Can you send me a more detail example of how it works? What type of shell do i open etc…
Please.
Thanks.
Please.
Thanks.
- Alanw
- 320 posts
alejandro
Hi!!
Please.
Thanks.
You need to have the Houdini environment sourced in whichever shell you're using.
Use the shell that comes with Houdini. It's in your programs menu, or type hcmd from Run.
This should work:
hython %HFS%\bin\slo2otl.py -v -l myshader.otl myshader.slo
You could also use Cygwin to source houdini_setup_bash and run
hython $HFS/bin/slo2otl.py
- 691 posts
Thanks Alan it works!!!!!!!!!!!
