Hello ppl
I need help for the procedure how to install Houdini in Fedora 13 and which version is required to download ..Thanks in advance 8)
Instal Houdini : Fedora 13
7343 10 1- kolektiv
- 6 posts
- Pagefan
- 519 posts
Just install like a regular linux version? That is, unzip and then run the install script as root. Since i presume you are running a 64bit version of Fedora you can get this houdini version:
http://www.sidefx.com/index.php?option=com_download&Itemid=208&page=license&version=10.0&build=659&platform=linux_x86_64_gcc4.3&format=tar.gz [sidefx.com]
- kolektiv
- 6 posts
Pagefan
Thank you will try
- kolektiv
- 6 posts
- Pagefan
- 519 posts
- kolektiv
- 6 posts
Pagefan
have a look at this link:
http://www.appistry.com/community/forums/content/cannot-restore-segment-prot-after-reloc-permission-denied [appistry.com]
Thanks now working, Houdini UI is broken :? http://i46.tinypic.com/33y2bzl.png [i46.tinypic.com]….Thank you for helping I will try Houdini in Ubuntu 10.04…
- Alanw
- 320 posts
Make sure you are installing Houdini to it's default location in /opt/hfs10.x.xxx
Also, make sure you are installing as root, but never run houdini as root.
If you have ever tried running Houdini as root then the simplest solution is to just delete /home/houdini10.0 and try again as a normal user.
The usual process for launching Houdini is as follows.
cd /opt/hfs10.x.xxx
source houdini_setup_bash
cd ~
houdini
cd /opt/hfs10.x.xxx
cd ~
houdini
- kolektiv
- 6 posts
Alanw
cd /opt/hfs10.x.xxx
cd ~
houdini
Tnx for advice, now only doubt betwen Ubuntu and Open Suse. I would probably first try Open Suse because i have a lot of hardver issue with Fedora 13..
- Pagefan
- 519 posts
- kolektiv
- 6 posts
- kumpa
- 44 posts
