Copy Sop
10432 13 1- Lyonz
- 114 posts
- pbowmar
- 7035 posts
- Lyonz
- 114 posts
pbowmar
The Copy SOP by default aligns the Z axis of the thing being copied to the normals of the template.
So, get your normals to face outward and Bob's your Uncle!
Peter B
Thanks for the reply,
I am using a basic curve that is closed and it only has 1 normal in the center, so ive added a point sop before the copy sop. I am still unable to get the point normals to go around with the flow of the geometry and have looked through the help file.
I am wondering what the expression would be as i have tried:
$TX2-$TX $TY2-$TY $TZ2-$TZ in the normal parameter and the only scale variable is PSCALE for particles.
The main idea is to create a chain with every other point been a box sphere and tube, this would create a necklace.
Lyonz
- tamte
- 8635 posts
- Lyonz
- 114 posts
- tamte
- 8635 posts
- tamte
- 8635 posts
- Lyonz
- 114 posts
- pbowmar
- 7035 posts
- Lyonz
- 114 posts
pbowmar
I'm obviously too late with my example then
One advantage is it lets you interactively adjust the normals in a fairly intuitive way…
I didn't know about the Polyframe, which is a cool SOP!
Peter B
Hi pbowmar,
Had a quick look through your method and im wondering how typing in $TX2-$TX $TY2-$TY $TZ2-$TZ worked for you ? As i found this in the help file but when i typed it in …nothing. Im wondering does it have something to do with the xform ?
Lyonz
Edited by - June 15, 2010 19:36:17
- pbowmar
- 7035 posts
Yes, you have to have the 2nd input be larger (or smaller, if you want the normals pointing inwards) to get the normals to do anything. If the two rings are identical you get 0 length normals, which aren't usually that useful
If you move the Xform up and down you can control the direction of the normals quite easily and interactively.
peter B
peter B
- Lyonz
- 114 posts
- pbowmar
- 7035 posts
- Lyonz
- 114 posts
pbowmar
Ah sorry. It's generating new normals that point from $TX (position of point input1) to $TX2 (position of point input2) etc. Essentially creating a new vector for the Normals from the point positions.
Peter B
Thanks i appreciate your explaination i think i full understand both yours and tamte's methods now.
