How do I make the wire colliding with my cloth like a RBD object or at least Static object ?
James.
Wire to collide with Cloth...
4652 5 0- James_Burg
- 153 posts
- Pagefan
- 519 posts
This is actually my first ever created dop network…(hurrah for the shelf!)
I made two cloth objects, changed some of the parameters on the wire object and then added some forces per object. Collisions are taken care of by the merge and clothsolver.
Is this what you are after? When you want an RBD object instead of two cloth object it is just a matter of adding a rbd object and a rbd solver.
Hans
edit:added the file
Hans
edit:added the file
- James_Burg
- 153 posts
- Pagefan
- 519 posts
- James_Burg
- 153 posts
- Pagefan
- 519 posts
Have a look at the help from the merge DOP it is explained there. If there is a mutual relation you can set it on the merge DOP.
Have a look at this helpcard in houdini's helpsystem:
http://localhost:48626/dynamics/relationships [localhost]
Hans
Hans
