Cell Animation Style Rendering w/ Mantra
   6251   4   5
Please advise where I can start learning how to create an animation with a cel shaded look in Houdini using the Mantra renderer if this is possible. Thank you in advance!
Best Regards, Jeff
for music check http://soundcloud.com/jeffali [soundcloud.com] All music is available for non-commercial animations free of charge. Just send me a message if you have any questions.
Hava look at the vex_cartoon SHOP.
You can also merge a wireframe SOP that has a constant shaded lighting model in VOPs with a semi-constant shader (see attached) to get shadows.
I'm not sure how you'd render intersections as lines though.
cdc.zip (27.7 KB)
Hi!!
Have a look at the Wren ROP also. :wink:
yeah composite a wren pass over a colour pass with some compositing you will get a good result.
you will be at the mercy of the wren pass.. not sure how it animates…
Nice easy technique, but I have trees and concrete balls (!) in my scene, is there a shader than can handle this? Thanks.
tea-time + rand(FF) = true
